Nardi to Momo to Spacer? | FerrariChat
Discussion in '308/328' started by Imatk, May 3, 2024.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    So I have yet to actually get seat time in my 308 aside from a very brief trip from garage to home.
    But I keep reading that getting a wheel spacer helps out those of us that are really too damn tall for these cars :)
    I'm 6'1" and have an '82 GTSi with a Nardi wheel. But all the spacers I see are for Momo wheels.
    Has someone done an adapter from the Nardi to the Momo and then done a spacer? And if so how do you like it?
  2. Steve Magnusson
    26,785
    Why not? You could even do a Nardi-to-Momo adapter, Momo spacer (if desired), and then a Momo-to-Nardi adapter if you want to stay with the Nardi steering wheel. You should probably do at least 25mm total or maybe 35mm minimum -- I'm a little taller than you, and used a 50mm spacer.
    Imatk likes this.
  3. dave80gtsi
    dave80gtsi Formula 3
    1,918
    Ohio
    Dave Meredith
    Imatk likes this.
  4. Imatk
    May 6, 2007
    768
    Do you find it's better than without the spacer?
  5. Steve Magnusson
    26,785
    WAAAAY BETTER WITH THE SPACER! ;) (if it wasn't, we would've removed them). Dave's setup looks like about 35mm total thickness (10mm adapter + 25mm spacer).
    Some minor points are to know the OD of the spacers/adapters you might use/buy (for example, 80mm OD are best for 308 while the TR steering wheel hub is 86mm OD), and the stock F horn button needs a mounting feature built into the spacer and/or a separate mounting piece.
    Imatk likes this.
  6. 4right
    4right F1 Rookie
    You may want to also consider an Eccentric Momo Hub Spacer that will also lift the steering wheel for additional leg room.
    Google Eccentric Momo Hub Spacer
    Imatk and Frisky like this.
  7. Imatk
    May 6, 2007
    768
    What brand would you guys recommend for the adapter and spacer?
  8. Imatk
    May 6, 2007
    768
    This is probably what I would do, I think I like the Nardi wheel and it's original so there's that.
  9. 4right
    4right F1 Rookie
    I used the same brand as the steering wheel.
