News
Nasty Gear Oil
Discussion in '360/430' started by slysnake, Dec 19, 2019.
  1. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    F1 360 Spider. Working on changing fluids starting with the gear oil. Here's a pic of what it looked like. Looks pretty nasty, what do you think?
  3. RedNeck
    RedNeck F1 Veteran
    6,092
    The CSA
    Me
    Check your coolant, make sure there is no milkyness. Could signify a failing heat exchanger.
  4. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,453
    Central NJ
    Dominick
    I agree .. if in doubt send out to be analyzed but looks like a heat exchanger failure ..if so ..fix it ..flush gear box two three times with gear oil or atf and then fill with gearoil and flush one last time
  5. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    That's what I'm thinking. I don't see any discoloration in the coolant reservoir but I'll drain the coolant and check it. If it's a failing heat exchanger will the coolant get into the engine oil as well?
  6. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,453
    Central NJ
    Dominick
    Yes usually the pressure of the coolant pushes it into the gearoil
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,668
    San Carlos, CA
    Mitchell Le
    But not into the engine oil. The heat exchanger only deals with gear oil.
  9. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,453
    Central NJ
    Dominick
    Correct but OP said gearoil .
    Sent from my moto g(7) using Tapatalk
  10. yelcab
    Nov 29, 2001
    10,668
    San Carlos, CA
    Mitchell Le
    He said ENGINE OIL here.
    radlu likes this.
  11. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,453
    Central NJ
    Dominick
    Sorry I thought you meant me or the OP .. my true apologies ..happy holidays
  13. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    Yes, Gear oil definitely looks contaminated to me. But I did also ask about the regular engine oil so thanks for responding to that as well. It stands to reason that a failing heat exchanger could cause cross contamination between gear oil and coolant but I wasn't sure if there would be a way for coolant to get into the regular engine oil that way. I guess if there's coolant in the engine oil that would be a bigger problem. I'll change the oil tomorrow. But there are no codes being thrown and the engine sounds fine so I don't expect to find any problems..... I hope. :)
  14. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    So were can I get a heat exchanger at a reasonable price? Ricambi?
  15. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    Any thoughts on allferrariparts.com? They seem to have the lowest price.
  16. blackbolt22
    blackbolt22 F1 Veteran
    Sep 25, 2007
    5,480
    Boca, FL
    Mr. Anderson
    I had similar problems with my 430. Bad heat exchanger for me.
  17. JoeTSI
    JoeTSI Formula 3
    1,165
    Huntsville, AL
    Joe K.
    That definitely looks like the early signs of a failing heat exchanger.
  18. imahorse
    imahorse Formula Junior
    534
    WI
    Dustin
    Looks like a failed heat exchanger. When it gets really bad, the trans oil will float to the top of the coolant resevoir. Replacement can be done by pulling the water pump and going in through the access panel or by pulling the intake manifold. Kinda a pain to get to. I flushed mine by filling it with gear oil, driving it around a bit so it warms up, then draining it, and repeating a few times. This failure happens due to coolant not being changed. There is a coolant pipe in front of the timing cover that I always pull when I look at timing. (Someone told me it doesn't have to be removed to look at timing, but I don't understand how). You may want to check your belts as well, because if the coolant wasn't changed, I doubt the belts were. A well known Ferrari dealer did a "major" on my car that was never done prior to my ownership. My heat exchanger failed and my belts were 20 years old. The two sometimes go hand in hand.
  19. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,364
    Uk
    Do you have any empty clear water bottles, the taller the better. Put the oil in them and leave it a few days to settle in a warm room. If its water it will settle out- then buy a new cooler
  20. yelcab
    Nov 29, 2001
    10,668
    San Carlos, CA
    Mitchell Le
    No worries man. I was too lazy to quote him.
  21. imahorse
    534
    WI
    Dustin
    Try eurospares
    Sent from my SM-N950U using Tapatalk
  22. SoftwareDrone
    SoftwareDrone F1 Veteran
    Regional Sponsor Rossa Subscribed Owner
    Jan 19, 2004
    6,374
    San Jose, California
    Heat exchanger. I've been through this twice. If your synchros go out soon you'll know why.
  23. slysnake
    slysnake Rookie
    Dec 1, 2019
    25
    Dan Proctor
    Thanks for all the advice folks. Looks like I have some work to do ahead of me. The holidays are going to put a crimp in my time now and then I'm off to Hawaii for a bit. I have drained the gear oil and put in fresh mobile1 75w90. Hopefully that will keep the car OK until I get back and can get to work on it. Thanks for the idea of Eurospares. I'll check them out.
    imahorse likes this.
  24. imahorse
    534
    WI
    Dustin
    Not a problem. If you have any questions, you are welcome to pm me and I will do my best to help.
  25. Need4Spd
    Need4Spd F1 Veteran
    6,090
    Silicon Valley
    There was an aftermarket maker of heat exchangers for these cars. It was American made I think, and far better made than OEM. He originally offered them on eBay but I can’t find any trace at this time.
  26. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,453
    Central NJ
    Dominick
    #23 flash32, Dec 21, 2019
    Try scuderiacarparts ..I think it is mid 500
