458 - Navigation Issue | FerrariChat
458 Navigation Issue
Discussion in '458 Italia/488/F8' started by craigburton, Jun 7, 2019.
  1. craigburton
    craigburton Karting
    Aug 27, 2016
    60
    I have an issue with the Nav on my 458 that i am hoping someone here may be able to help with... The location of the car is totally wrong, so although the nav 'works', it doesn't know where I am, HELP?
  2. boogie
    boogie Karting
    Mar 4, 2016
    192
    Boston
    Keith
  3. Principissimo
    Principissimo Formula Junior
    Sep 14, 2015
    838
    Milano
    Bruno
    First trial i’do is detachment of the battery for a minute.
    This usually solves a lot of issues ;)
    AClark likes this.
  4. craigburton
    craigburton Karting
    Aug 27, 2016
    60
    Thanks! I will try that tonight... will update you
    Principissimo likes this.
  5. alfheim
    alfheim Rookie
    Aug 25, 2008
    6
    And while we're on the issue, does anyone know if it's possible to update the map's? Last I checked I couldn't find anything. But driving round with maps from 2009 makes the nav less and less useful. I'm in Europe, but interested if there is an update in the US too as I haven't found anything.
    Sent from my SM-G930F using Tapatalk
  6. craigburton
    craigburton Karting
    Aug 27, 2016
    60
    Okay, tried the battery disconnect and reconnect procedure and it still thinks it’s 57 miles away from where I actually am [emoji853]
  7. pdxjim488
    pdxjim488 Karting
    209
    Regarding detachment of battery, I am trying to do that. With the radio on, I pull the lever at the base of the battery and the radio stays on. Am I doing something wrong?
  8. craigburton
    craigburton Karting
    Aug 27, 2016
    60
    You need to make sure EVERYTHING is OFF... that includes a/c, radio, fan, lights, everything. THEN undo the fast release clip on the battery and remove the cable from the terminal entirely... then follow the reconnect sequence in the owners manual... it’s not as simple as putting it back on after 1 minute either, so you must make sure you follow the correct procedure...
    Also make sure you open the windows before you disconnect! If you don’t you run the risk of breaking the window if you try and open or close the door
    pdxjim488 likes this.
  9. thebigo
    thebigo Karting
    Feb 10, 2019
    79
