Need 328 diagnostic help! | FerrariChat
Discussion in '308/328' started by plugzit, Oct 3, 2016.
  1. plugzit
    plugzit F1 Veteran
    7,784
    Redondo Beach, CA
    Bruce Bogart
    Here are the symptoms:
    Idles OK, but not great. Not missing.
    Won't take throttle cold.
    Will rev, but not happy to, requires very light throttle to do so.
    Little to no power.
    Here's what I've checked:
    Cam timing spot on
    Fuel pressure (static) at 40lbs
    Distributors ok
    Compression consistent at around 150
    Spark plugs mostly tan, getting fire
    Cold start checked by disconnecting/connecting
    Aux air valve good
    Sprayed brake cleaner liberally checking for vacuum leaks, no love there.
    Exhaust free, not stopped up.
    CPS clean, magnetic.
    I think that covers it all.
    I'm out of ideas!
    Dammit, I've been trying for two weeks to diagnose this thing and getting nowhere. I hope I've missed something idiotic!
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    If this was an non-computer-controlled ignition, I'd suggest badly retarded ignition timing. I'd say the same thing now but I have no idea how that can happen on computer-controlled ignition.
  3. Steve Magnusson
    26,876
    If a US version 328, have you checked to see if the frequency valve is buzzing/vibrating when the fuel pump is running (it should). If not, you'd need to look at the Protection Relay.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    What is the voltage coming off the O2 sensor when it is hot, and idling?
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Verify you are getting spark to all the cylinders. look for problems with ignition wires / plug extenders.
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Might check throttle switch, should click with slight throttle movement.
  7. lopena
    lopena Formula Junior
    760
    ^...this...^
  8. plugzit
    plugzit F1 Veteran
    7,784
    Redondo Beach, CA
    Bruce Bogart
    You, sir, are my personal hero for the day! I hereby accord to you all the rights and privileges thereof!
    Explanation:
    In my shadetree wisdom, I checked the frequency valve for operation by powering it and blowing thru it. It worked, as far as that goes. Not being expert in 328, I wasn't aware of the presence of a relay controlling its operation. Upon finding the relay per your advice, located attached to the underside of the finishing panel on the right side of the trunk (it's a Mondial 3.2). It was not plugged in. It was laying in the fenderwell! Voila!
    The good news....I've been thru (pretty much) all the systems in the car, and they are operating properly now.
    Thanks again Steve
  9. Steve Magnusson
    26,876
    Glad to give you a small nudge in a direction that matched your symptom well (all 8 cyl seeming to run, but just uber-weakly). I can tell you that your report of "it fell out" is a new first for us, and seems impossible ;), and, many times, Mechanics wrongly go after resetting the mixture.
    Two things every K-Jet with Lambda Owner should learn to do (even if they don't how to use a screwdriver and are dressed in a tuxedo): 1. Touch the frequency valve to calibrate yourself for when it's working correctly (so you can quickly confirm/deny when you are having a problem), and 2. unplug the safety switch and turn "on" the key to get the fuel pump running without the engine running -- can tell you instantly (by sound) whether or not the fuel pump is working.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    Out of interest what does this frequency valve do ?
  11. Steve Magnusson
    26,876
    The frequency valve is a "controllable leak" from the lower chamber of the fuel distributor back to the tank. During normal warm-running, it gets a 50% duty cycle from the ECU so is open 50% of the time. When the ECU wants to add richness, it increases the duty cycle to the FV = FV open more often = lowers the lower chamber pressure = lowers the upper chamber pressure = increases the pressure drop across the slit = more fuel flows thru the slit for the same size slit opening (i.e., more fuel is added for the same amount of air entering the engine). To go lean, the opposite of all those events occur. When there's no +12V power from the Protection Relay to run the ECU (which runs the FV) = the FV stays closed all the time = lower chamber pressure much higher = upper chamber pressure much higher = pressure difference across the slit much lower = less fuel flow for same size slit opening = way, way lean = runs very weakly, if at all.
    (The bottom line is if no FV operation = way too lean).
  12. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    thank you for this explanation, Steve ! :)
  13. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    But remember that, as far as the 3,2 liter engine goes, there are three different variants; and as said by Steve in his first sentence, "if this this a US variant..." means that it won't apply to the "Euro" engine, which is Non-cat (so no Lambda probe)
    I don't think there is a frequency valve on the Euro engine (non cat), is it, Steve?
    On the Swiss engine with Cat, which has another K-Jet variant, there is a thing looking like a frequency valve but fitted vertically instead of horizontally and in the same place, that I think is called a "fuel pressure regulator"; its purpose is probably more or less the same?
    Rgds
  14. Albert-LP
    Albert-LP F1 Veteran
    8,177
    around Modena, Italy
    Alberto Mantovani
    If the problem is just when the car is cold, I would say the warmup regulator gone, for an Euro car. US cars have so many stupid antipollution devices that I don't know.
    ciao
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,968
    Isle of man- uk
    Its that simple then ? Give me a few days to work it out , now i know but not sure i bet it. Ta
  16. Steve Magnusson
    26,876
    Correct.
    Euro 3.2 = K-Jet without Lambda (has WUR, no frequency valve, no protection relay)
    US 3.2 = K-Jet with Lambda (has WUR, frequency valve, and protection relay)
    Late Swiss 3.2 = KE3-Jet (has EHA instead of frequency valve+WUR combination and has protection relay)
    Mattroot likes this.
  17. nerofer
    Mar 26, 2011
    12,083
    FRANCE
    Thanks Steve.
  18. kurtbob
    kurtbob Karting
    Jun 2, 2013
    64
    Augusta, GA
    Kurt
    Where is the Protection Relay located? Is it that big relay in the passenger side trunk area on a 328?
  19. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #19 ME308, Oct 21, 2016
    yes
  20. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,142
    Atlanta
    Tom Spiro
    I had this happen to me as well, I don't have a clamp on the relay, so it would just hang ... so I made a clamp, about 10 years ago, have not had a problem since.
