Need 348 flywheel pic. | FerrariChat
Discussion in '348/355' started by Gimme Fuel, Jul 28, 2006.
  1. Gimme Fuel
    Gimme Fuel F1 Veteran
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Hi
    Could someone please post a pic of the INSIDE of the 348 (dual disc) flywheel for me??? BEFORE the grease is put on.
    I've just opend mine and found lots of small parts and a "pile" of old, smelly grease..
    So I would like to know how you can reasamble it.
    I DID a search and found a couple of pics, but I'm not sure if that was a single plate or dual discs.
    Thank you very much in advance.
    Now, it's cleaning time! :D:D
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  4. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    WOW...perfect guys, thanx a lot.
    I'm sitting here with 62 parts, no wonder you get a bit :confused:
    From these pics I see you start the repacking by placing down the "springs" first,THEN cover them by the 2 simular dark-gray discs...is there any spec. gap between those two discs??????????
  5. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Check out the second pic from your post...
    I've got 2 short and 2 long springs, which one goes where???
    (from top left)
    is it long, short, long, short???
    Another thing, note those small "blocks" on the brown plate, all 4 of them have a tiny groove in them, pointing inwards to the center of the premiter, when I opend MY FW they were pointing the opposite :confused: is that a big deal????
  6. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Going clokwise that sounds correct.
  7. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    OK, thanx Ernie...
    So the correct way is: (going clockwise)
    LONG.............SHORT
    LONG..............SHORT
    Then the "exploding" has a wrong setup, I meassured the springs on my
    screen (LOL can you picture it) and I came up with:
    LONG..........SHORT
    SHORT..........LONG
    OK...just two more quiz here and I'll be off :D:D
    Those 2 DARK-GRAY simular discs, is it supposed to be any gap/distance between them???
    And should I press the DARK-GRAY discs all the way down on the center "cog" until they come to a halt in the tiny-tiny blockers, which are located on the center "cog"??????
    I hope some1 of you know the answer to this and will be so kind to post it :):)
    A can of grease is on the way now from Mr.Pass! :D:D
  8. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    Pics of this is coming soon :):)
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    I take it you figured it out.
  10. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,441
    Belgium
    Jurgen Durand
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Just for clarification, the internals are the same, the outsides are different for the single & dual clutch.
  12. Gimme Fuel
    Mar 15, 2003
    9,428
    In my 348
    Paul (Norway)
    oh...this thread..
    glad I'm done with it :D:D:D
