Need 348 geometry settings | FerrariChat
Discussion in '348/355' started by angelis, Mar 29, 2006.
  1. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Can someone give me the geo settings for a 348 GTB please. I've checked and I can't seem to find it on the forum.
    Could I use the standard settings or would I need different ones as I have 355 wheels, lowere suspension and 25mm spoacers on the rear?
  2. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    You'll need non standard ones based on your new bits and pieces; you'll also want to decide if you want an aggressive (track biased) or street setup, whichever way you choose to go get a workshop with alot of experience with Ferrari's do it (should be around £100-£150)
  3. Mike in ATL
    Mike in ATL Karting
    Nov 2, 2003
    127
    I have a 1990 348 with 360 wheels. I had a 4 wheel alignment done in Nov 2005, here is what they said it took:
    Front Camber -.6 caster 5.6 toe 0.18 (Degrees)
    Rear Camber -1.6 toe 0.21 (Degrees)
    I dont know where they got thier info but they are a high end shop.
    Good luck
  4. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    Did the 348 challange had different settings then the normal ts,tb,... ? Wich settings they use? Some good complete (chamber, toe in, caster, kingpin) allround setting for the hobby circuit driver?
    Standard should be
    front :
    chamber : -0°30' / -0°50'
    toe in : 2 / 3 mm
    caster : 5°30' +- 15'
    kingpin : 12° 27' 33"
    rear :
    chamber : -1°50' / -2°10'
    toe in : 2,5 / 3,5 mm
    caster :
    kingpin :
    ____________________
    Samy
  5. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    The 348 Challenge manuel had different settings. More aggressive for track. I think fronts -1.5 and rears -3.0 camber. I will check this evening in the '94 manuel and post for sure.
  6. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    Official challenge manuel from '94. Camber value must not exceed the following maximum:
    Front - 1 40'
    Rear -3 15'
    No mention off toe in.
