Need 355 Cats | FerrariChat
Need 355 Cats
Discussion in '348/355' started by dougburhyte, May 26, 2017.
  1. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Hi Folks,
    I'm looking for a set of OEM catalytic converters for my 1999 355. Slightly used is fine; for example, if they were removed by someone replacing them with an aftermarket set-up, but they need to be able to pass California's smog requirements. Any leads would be most helpful. Thanks!
    Doug
  2. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    You should get the SoCal guys to chime in here as many have had exactly the experience you are having. Trojanfan recored his OEM cats through fabspeed and passed for example.
    I'm on the other side of the country so only speak tangentially on this from a CA perspective.
    Hopefully others will chime in.
  3. f355spider
    f355spider F1 World Champ
    18,044
    If you get the 1999 model year cats, they are metallic, versus ceramic and much more durable and won't crumble like the earlier ceramic ones. My experience with recoring was less than satisfactory (metallic cores). They worked for about a year, then threw "low catalyst efficiency" codes. Extenders eliminated the problem, but that just means you will never know if the cat is actually working or not, cause the secondary O2 sensor is out of the path of the exhaust. I found some new, 1999 oem metallic catalysts on Ebay for a song and never looked back. :)
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Interesting because I had to change my 99 cats for hyperflows in 2007
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I believe metallic core were used near the end of production. I don't think it was exclusive that all 99's had them.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    What are some of the last 99 build dates then
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    No idea, Grant. Dave Helms was the first to educate me regarding OEM metallic cores. I was hoping my 98 would have them but they were ceramic.
  8. SethP
    SethP Karting
    Jul 2, 2014
    89
    Corning, NY
    Seth Parks
    Are you looking to borrow or buy?
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    #9 SoCal1, May 27, 2017
    You do not need OEM cats to pass smog
    CARB approved cats will be fine as long as you have the certificate for them
    Anything over 7 years old or 70000 miles can use aftermarket CARB approved cats.
    I build my own as got tired of the small inefficient one's offered for our aftermarket. Sorry I dont sell them just do it as a hobby.
  10. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    Another reason 95s are bets.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    How is a 95 going to be better in an area that does sniff testing?
  12. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Seth - I'm interested in buying.
    Doug
  13. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Seth - I'm looking to buy.
    Doug
  14. 348 TB
    348 TB Karting
    Nov 9, 2003
    120
    Mich
    Mike V
    How do you build them?
    I like to do it myself for my 92 348 tbspeciale.
    thanks in advance.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Basically a box of stainless tubing, flanges and a cat start welding :)
    Need to get a machine shop to cut flanges is about the hardest part rest is just welding.
  16. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Mine was in March of '99.
    Doug
  17. dougburhyte
    dougburhyte Karting
    Dec 28, 2005
    166
    Douglas Burhyte
    Thanks for all the good input. I did indeed look into the "universal" cats as a replacement, but my mechanic said nothing fits without extensive rebuilding/configuration. He was then fortunate to find a set of used cats that come with a six-month warranty from the seller. So, I should be able to get the vehicle smogged successfully once installed and then have a couple of years to figure out if some universal ones that readily fit become available.
    Doug
  18. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    1,154
    Sarasota, Florida
    OC
    I have a set if your not in a hurry. Pm sent.
    Sent from my SM-N920V using Tapatalk
  19. LEF LANE
    LEF LANE Rookie
    Jul 3, 2008
    19
    South FL
    I'm about to Fab some test pipes for my 95 355.
  20. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    I was hoping all the replacement OEM cats would now be metallic, but I asked the folks at Eurospares and they believe they are still ceramic. Can anyone confirm this?
  21. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,165
    So. CA & NV
    Peter
    Just to chime in, I had my factory cats re-cored by Fab Speed 3+ years ago and no issues. I have them tested each year and they are reading very clean.
  22. Qavion
    14,290
    Ian Riddell
    Thanks, Peter, but I don't understand Fabspeed's pricing. According to their website, they're asking Australian $3,943.82 to recore my old cats with HJS trimetallic cores (and I'm assuming postage to/from the USA would be additional). If all the OEM ones now have metallic cores, it would be cheaper for me to buy new OEM ones from the UK.
    Of course, the Fabspeed recore material may be better quality, freer flowing, etc, but I don't know if the difference would be noticeable to me in the short or long term.
  23. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    And you'd have to pay tax on the way in too! Not a viable option IMO.
    I have a spare set of OEM gutted cats that I will one day get around to recoring locally.
  24. Qavion
    14,290
    Ian Riddell
    Do you know of anyone Sydney (or Australia) which does this, Elliot? (and makes the welded seams look original)?
  25. INRange
    INRange F1 World Champ
    12,546
    Virginia/Florida/Caymans
    JD
    Doug,
    In my opinion, your best bet is to find a set to re-core. I just sold my set (1998 Ceramic) on Ebay to a someone in California who plans to re-core them. They started to throw codes and were basically internally falling apart. I replaced them with Fabspeed cats and passed the emissions with no problems. Fabspeed uses the same metallic core that I have when they re-core the original units.
