need a 246 distributor | FerrariChat
Discussion in '206/246' started by Newman, Sep 27, 2010.
  1. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,499
    Canada
    Newman
    Took the distributor apart today and its destroyed inside. The pivot posts for the weights are trashed, because of that, the weights swing out on an angle wearing a big groove in the two slotted tabs that control the shaft's advance (almost wore right through) and the weights themselves are damaged. Anyone have a distributor for a 71 246 or some internal parts? The housing is fine but thats about it!
    Thanks.
  2. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,814
    26.806311,-81.755805
    Dave M.
  3. Newman
    Dec 26, 2001
    14,499
    Canada
    Newman
    Thanks Dave that covers what I need, im surprised they have all the internals.
    Paul.
  4. pgb67
    pgb67 Karting Silver Subscribed
    Oct 8, 2006
    192
    Long Island,NY
    PGB
    Newman,
    I just went through this on my 246. This was the 2nd time the brand new weights came apart in about 8000 miles. what I did was install an MSD programable ignition. I had already gotten rid of the points and put in a trigger wheel and pickup. Now no more weights the advance is set with a laptop. The car has never run better. PM me if you would like any more info would be happy to help.
    Peter
  5. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    superformance does have all the internals and you will get your car back on the road with their stuff BUT their stuff is NOT plug-and-play, their weights will need cleaning up, the springs are much too strong and you will need someone with a distributor machine to set up the distributor. I was quite disappointed with the superformance quality but since I have a distributor machine, I was able to get everything working with their parts.
  6. alhbln
    alhbln Formula 3 Consultant Owner
    Mar 4, 2008
    1,750
    Berlin, Germany
    Adrian
    Good idea, that would be a similar approach as with the BSMpdi setup. If you weld the upper T holding the rotor (which you can also get from Superformance) to the axle and remove the weights, you have a locked out distributor and can do the timing via the MSD 6530:
    http://www.msdignition.com/Products/Ignitions/6530_-_MSD_Digital_Programmable_6AL-2.aspx
    With such a setup you can also easily run a more optimized advance curve without spending time at the distributor machine to get the curves right.
  7. Newman
    Dec 26, 2001
    14,499
    Canada
    Newman
    Thanks for the great info Peter , ill get the distributor first and consider your update. Now I just need to sort out the Magnesium valve cover treatment to get them looking right!
    Paul.
  8. dm_n_stuff
    Dec 10, 2003
    43,814
    Dave M.
  9. smith1215
    smith1215 Rookie
    Jun 3, 2006
    23
    connecticut
    steve smith
    I have one which probably needs rebuild Given that, it's complete and seems OK. If you are interested, call me 203-561-9870.
    Steve
  10. smith1215
    smith1215 Rookie
    Jun 3, 2006
    23
    connecticut
    steve smith
    I forgot to give you my email address. Steve@elljescom
