355 - Need a 355 Flywheel & clutch housing | FerrariChat
355 Need a 355 Flywheel & clutch housing
Discussion in '348/355' started by Tarek307, Feb 16, 2022.
  1. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Hey guys i'm looking for a 355 flywheel and clutch housing (pumkin cover) for a 98' Berlinetta , the housing is available from euro spares for not too much new, so flywheel is what i'm more interested in- Thought i'd take a shot here before ordering parts. I'll also contact Bradan regarding rebuild of flywheel as an option
  2. Qavion
    Qavion F1 World Champ
    14,328
    Ian Riddell
    What broke? What was causing your rattling noise?
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Let's not confuse the flywheel and The voirh dampener. Billet flywheels are available from superformance. Voith is available used. Pumpkin new and used, I'd go used.
    Sent using FerrariChat.com mobile app
  4. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
    Qavion likes this.
  5. Qavion
    14,328
    Ian Riddell
    Thanks! Hopefully I've caught mine in time. One day it wasn't there, one day it was. How long did you have the noise?
    Just wondering if I should get my car towed to my mechanic, 10 miles away.
  6. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
    #6 Tarek307, Feb 16, 2022
    I bought this 98' Berlinetta F1 about 2 weeks ago and it had the sound already..it drove and shifted fine, previous owner isn't exactly a car guy and he bought it that way too thinking its a normal sound, so who knows how long it was there- He owned the car 2 years but didn't put many miles on- (mileage is 55K) PO did break the propeller shaft and that needed to be replaced, but when the car went to the shop he didn't tell them about the rattling (and it obviously wasn't running when it went there) so they fixed his broken propeller shaft and put car back together and i guess they didn't notice the rattle and he picked it up..that was 5-6 months, now the shop is telling me most likely thats what caused his propeller shaft to break in the first place and if he would have mentioned the rattling sound they would have investigated further..so i gotta do all this work now.
    PS: you should be just fine driving it 10 miles to your shop..but don't take my word for it lol
    Qavion likes this.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Video of voith repack.
    As far as the pumpkin unless the bearing would not seat anymore I would not replace the pumpkin for that minor scraping. That grease flung out you need to inspect the voith for cracks, only way that much grease comes out is if the case is damaged. The voith bolts to the flywheel.
    The video will make it clear.
  8. phrogs
    phrogs F1 Veteran
    7,347
    Kzoo Michigan
    I do have a spare flywheel it would need to be surfaced and mostly likely have the grease repacked.
    It came out of a F1 trans I needed parts from. I sold it as well as the cover but I do have the flywheel.
  9. Ferrarista98
    Ferrarista98 Formula Junior
    284
    Jason L
    Glad you were able to source the problem. Sorry it was not as simple as hoped.
  10. 26street
    26street Formula Junior
    Jan 30, 2021
    470
    Westchester New York
    Mark k
    Have you look into a machine shop that can weld up the area and then machine it back to spec
    I have done that with other parts (head, intake and mounts) that had cracks and was way cheaper all where aluminum parts
  11. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
  12. Qavion
    14,328
    Ian Riddell
    Which part is causing the damage? The flywheel inner shown in the photos in the post above or the part with teeth for the starter... or none of the above?
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The voith damper rubbed the housing. Probably the rivets which are in fine shape. It also threw grease which is not related to the voith rubbing. Not sure why the billet flywheel needs replacing, or the voith unless it's cracked from reusing clutch bolts. The pumpkin is hit or miss the voith rests on the bearing inner race not the housing. I'd be shocked it any of it needed to be replaced except the voi g which needs to be I inspected to grease escapment.
    Qavion likes this.
  14. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,770
    Lake Villa IL
    Looks nice. Probably wouldn't be of interest to most but did you happen to compare weights?
  15. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    I did not put it on the scales but it was very noticeably lighter and very well made.
    Notice the balance holes on the standard flywheel, then notice how there are none on the new flywheel. So clearly machined to tight tolerances.
  16. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
    problem is i need the entire flywheel not just the part that touches the clutch ...why did you need a flywheel? what happened to yours?
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Actual Flywheel plates wear over time, you can machine them but then they warp or wear sooner and gaps and tolerance can get thrown off, alternatively you replace them. The billet flywheel disk is a consumable part, like clutch plates. The Voith damper that bolts to the billet disk is rebuildable.
    Jackie and bill and Tarek307 like this.
  18. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    The part that touches the clutch is called the flywheel. The other parts your talking about is the damper. As said they can be rebuilt.
    I replaced because it was very worn.
    Just look at the face of the old flywheel in the pictures compared to the new unit.
  19. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
    i was able to get the parts, hopefully they are the correct parts and i can get this baby back on the road again without the rattling sound
  20. Brian GTS
    Brian GTS Rookie
    Dec 23, 2020
    16
    Brian
    Where did you get your parts? I’m looking for the o-rings (seals) to rebuild my damper. Thanks!
  21. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    They're no individual parts for the o-rings that are inside the damper. You have to take them measure them and buy them online from an o-ring supplier . For the damper there are no seals just the kluber grease , o-rings around the bolts and the large o-ring for the two cases. Beyond that there are two bearings you can replace if they need replacing.
