Need a clutch for York AC compressor | Page 2 | FerrariChat
Discussion in '308/328' started by rocket50, Oct 31, 2020.
  1. BigTex
    79,406
    Houston, Texas
    Bubba
    That's the issue, the belt size.
    It's easy enough to source a single grove cluthc for the York but it's off a Deera tractor..only Ferrari unit has the metric belt v groove.
    Time to make some or go with a Sanden
  2. afterburner
    afterburner F1 Rookie
    3,501
    Switzerland
    Urs STEMMLER
    ... because it rotates the other way round.
  3. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    Why does the sense of rotation of the magnetic clutch matter ?
    Best from Germany
    Martin
  4. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    Martin, I think the plates linking the compressor to the pulley are working in tension. If you reverse the pulley direction, they need to be fitted to the other side else they'll buckle under compression load:
    What do you think - could that be the reason?
    Best regards
    Urs
    Saabguy likes this.
  5. Hinecker
    Hinecker Formula Junior
    Mar 14, 2011
    379
    Martin308GTB likes this.
  6. Hinecker
    Mar 14, 2011
    379
    Afternoon,
    You are correct, the plates would have to moved around in order to be ok. The pulley in the picture is meant to work clockwise. On a 328 the compressor turns counter clockwise.
    John.
  7. afterburner
    3,501
    Switzerland
    Urs STEMMLER
    well... those bars do go the same way as my pic, don't they? So it should work fine. Did you add Gates belt type pulley on a different clutch?
  8. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    Hi John,
    looks good. Did you perform the job yourself? Did you add something like Loctite 648 or is ist just a press fit?
    Best from Germany
    Martin
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Aka green weld juice!
  10. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    Indeed. Recently we tested a just 40mm diameter loose fit of 30mm length assembled with Loctite 648 after 48 hrs. curing time on a hydraulic press. There were 70 kN shear force necessary to break it.
    Best from Germany
    Martin
  11. Hinecker
    Mar 14, 2011
    379
    Afternoon Martin, nice hearing from you!
    No, I had it done at a machine shop. Nope, no "glue", once pressed together(core and pulley), a hole was drilled at the union of both parts and a 5mm pin was pressed in for safety. It's been holding for 5 years now, so far so good.
    As you know I live in Southern Spain (really hot weather), A/C is used 6 to 7 months yearly.
