Need a diagnostic....F355 spider | FerrariChat
Discussion in 'Technical Q&A' started by Gershwin, May 4, 2007.
  1. Gershwin
    Gershwin F1 Veteran
    Feb 21, 2005
    6,415
    Kentucky
    Returning yestderday evening from a charity event and I was getting the air-bag sensor light and my in dash escort was going bonkers. Power on the car began to slowly fade especially when I turned on the a/c. Car began to run rough and sputter, luckily was able to cost as I lost all power and car quit in a Chevron gas station.
    Now it sounds like alterntor but a fellow F-enthusiast believes don't rule out the volt-regulator.
    Does anyone have any other ideas?
  2. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    The voltage regulator is IN the alternator. Most times, a "rebuilt" alternator is just an alternator with a new regulator installed. If you are handy, you can easily do it yourself.
    JM
  3. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    You need to change the diode pack too. Chances are the brushes and bearings are okay. An easy DIY once you get the parts and wrestle the thing out of the car.
    Ken
  4. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    exactly
  5. Private_Joker
    Private_Joker Formula Junior
    May 2, 2007
    271
    718 and 978
    Tom
    +1, when I learned how to do it, it was a "that's it?" moment.
  6. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,053
    What he said...do a search here and you will find several useful threads on obtaining a new, better quality regulator than the factory oem Nippondenso one.
  7. J. Salmon
    J. Salmon F1 Rookie Owner Rossa Subscribed
    Aug 27, 2005
    4,367
    VA
    I had mine in the 512 rebuilt by the local alternator expert. He actually lives at the junkyard where he works. He thought it was highway robbery to charge $100 (the 512 has a BIG alternator). Works like a charm.
    Check all your connections and voltages. The alternator can stop working because of a wiring issue (no tickle charge to one of the plug leads) and it appears for all the world like it's internal. Have them verify that it is not working, and that it is 100% before putting it back in.
  8. Gershwin
    Gershwin F1 Veteran
    Feb 21, 2005
    6,415
    Kentucky
    Thank you for the help fellas!
