need a good repair shop for 1985 928s | FerrariChat
Discussion in 'Porsche' started by bocaf430, Feb 9, 2019.
  1. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    I am in need of a good repair shop here on long island Suffolk county for a 1985 928s , I feel the car is not running as it should, stiff gas pedal, ac fan knob not working but a/c works and heat works when you slide it to defrost..but only fan is on high.. reverse lights not coming on and transmission I feel doesn't down shift as it should.... thank you
  2. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,659
    NOLA
    Chris
    Check on Rennlist. I believe there is a fellow on there in Long Island.
  3. NYC Fred
    NYC Fred F1 World Champ
    16,124
    Fort Lauderdale, FL
    Fred C
    http://www.rennwerke.com
    If you can make it to Westchester I can't recommend Cheech at Rennwerke highly enough.
    Have sent a number of Porsche buddies over there with terrific results.
    Right off the Cross Westchester in Elmsford.
  4. FiatRN
    FiatRN Formula Junior
    Nov 21, 2008
    319
    Denver, CO
    Jonathan Drout
    As above, check Rennlist o help locate quality locals.
    "stiff gas pedal, "
    Unless it has changed since you have owned it, this is often a 928 "feature." But make sure the cable isn't frayed - unhook it from the cross at the front of the engine and see how it feels when actuated by hand.
    "ac fan knob not working but a/c works and heat works when you slide it to defrost..but only fan is on high.."
    you might have magic-fan syndrome. That's usually the fan resisitor.
    "I feel doesn't down shift as it should"
    the kickdown cable likely needs adjustment.
    These should all be easy things for a 928 knoweldgeable wrench, or for a do-it-yourselfer if you so desire.
    Best luck and enjoy that '85!
  5. cgt000
    cgt000 Formula Junior
    780
    Northeast
    Carrera Car Shop. Peter Potzinger. Huntington Station
  6. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    thank you
  7. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    Yeah, that's a LONG damn cable from pedal to throttle. My '83 was reasonably smooth, but my '87 S4 was pretty stiff. Lubricating the pulley up under/near the air filter box helped quite a bit.
