need a little advise re fuel tank colour | FerrariChat
Discussion in '206/246' started by pk246gt, Feb 3, 2010.
  1. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    was there a standard colour fopr fuel tanks?
    Have seen gold and silver...
    paul
  2. boxndoc1
    boxndoc1 Karting
    Jan 25, 2007
    147
    North America/Italy
    If it means anything, my engine had never been out before we did it. and it was a light gold/tanish color. also vincent latino of autoelite in new jersey(ft lee) has the correct color if you want to call him. But i just checked the photos and it was that tan-gold color. good luck
  3. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    206 and L-serie are black original
    M- and E-serie tan-gold colour
    never silver...
    regards Matthias
  4. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    thanks guys.
  5. swift53
    swift53 F1 Veteran
    8,312
    E.S.
    Alberto
    Matthias, are the L series covered in fiberglass? Mine were, but as they leaked, I had to strip it all off. Regards, Alberto
  6. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Hello Alberto,
    yes, it original. Only with 206 GT and L-serie !!
    It`s a kind of fiberglass filler and painted black.
    Regards Matthias
  7. swift53
    swift53 F1 Veteran
    8,312
    E.S.
    Alberto
    Thank you, Matthias! Regards, Alberto
  8. dinogts
    dinogts Formula 3
    So, after the 206 and the L series, what is the material on the outside of the fuel tanks?
    Some have asserted that it is simply an undercoat (at least one person says that a beige Wurth undercoat is the same, or nearly so) that has been painted, but that doesn't appear to be the case, and it doesn't appear to be simply painted over. I have been told by various old-school professional restorers that the material used was selected as an insulating surface to keep the fuel temperatures as low as possible, especially considering that the gas tanks are in a compact engine compartment (think about that for a minute!) to reduce the risk of fuel pump cavitation and to reduce the risk of fire.
    I have been cleaning the outside of my tanks with gentle dish detergent (Dawn) which works great at removing the built up grease and dirt. While they have cleaned up a lot, they don't "sparkle" and there is what appears to be some staining of the surface.
    I have seen some that appear to be a fairly bright gold color, but I am not convinced that is correct.
    So,
    1. What is the material on the tanks?
    2. Is it still available?
    3. What other options that meet the insulation/safety requirements but look period correct?
    Mark
