Need a little help on front grill and heater wires for 22641 | FerrariChat
Discussion in '308/328' started by arcticlighting, May 9, 2018.
  1. arcticlighting
    arcticlighting Karting
    Oct 5, 2007
    184
    Spokane, WA
    Brian Chapman
    Can someone please help me on the front grill. I’m not sure if the brackets mount with rivets or with a small screw with a nut behind it. What I took off was misc screws with nuts and hard to find out what was original even in the parts catalog. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Trying to put it back as original as possible.
    This is a 1977 308GTB.
    Also need to know what order these wires go in. The kid took them off and didn’t mark them. Image Unavailable, Please Login
    Thank you. If you want send pictures to my phone if it’s easier
    509-370-3623
    Thank you. Getting closer to being done after 3 years. Hope by mid June for a big show in Seattle in July.
    Brian Chapman
  2. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    I can’t help you with the nuts and bolts but eager to see what others say as I’ll be asking the same question when mine goes back together. Here’s a picture of my resistor wiring when I was stripping my car for painting it’s an 81 GTSI Image Unavailable, Please Login
  3. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
  4. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Interesting the resistors must flipped upside down depending on LHD or RHD
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,248
    Gold Coast, Aust.
    Patrick
    The grill is held by screws, not rivets. The resistor is easy, just use a test light - it's also in the wiring diagram. BTW, if you want to improve the a/c, run a relay on the high speed wire at the fan motor - blows about twice as much air.
  6. arcticlighting
    Oct 5, 2007
    184
    Spokane, WA
    Brian Chapman
    Thank you all for the pictures and information.
    Will just get some small machine screws and nuts for the grille
    Will do stainless.
    Thanks hope to be finished in 3 weeks
    Brian
  7. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    #7 i-velocita, May 16, 2018
  8. i-velocita
    2,520
    Colorado
    James
  9. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,333
    maurice T
    +1 with this mod..I did away with the resistor on my GT4 and hooked up a relay to the high speed as I never ran the fan on low and medium anyway..
    I tested it with a anemometer and the increase in fan speed was quite substantial..
  10. arcticlighting
    Oct 5, 2007
    184
    Spokane, WA
    Brian Chapman
    Wow thank you so much for the pictures and the fan info.
    Are you able to let me know what wires you tied together for making the fan run on high or is that in the wiring diagram??
    Thank you so much for the screw pictures too. I’m just trying to get it as correct as possible.
    Not that a judge would see the screws.
    Thank you again
    Brian
  11. BigTex
    79,397
    Houston, Texas
    Bubba
    #11 BigTex, May 18, 2018
    The grill mounts to the tab with metric bolts, as Jim suggests.
    Mine are hex head, M8 from memory....
    I need to look to confirm but Ferrari used rivets were possible so I think Newman might confirm on his early Boxer jobs, the tab itself may rivet thru the fibreglass valance.
    Rivets weigh far less, explains Ferraris fondness of them, but screws are incorrect, they will score the tab, which is only alimunum. On my car the tabs themselves were tapped with threads, for the machine screw or metric bolt.
    Good to see you!!
    Turn tab around, long side goes to the valance.....I am not home but will get pictures
  12. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    I have a RHD 1980 carb model GTS . I will need help of any owner here has pictures of the front compartment areas how to install these heater valves , piping etc . My car restoration is almost done but the mechanics old phone that has many of my car pictures was broken so I lost everything .
    I am trying my very best to slowly put things back . Is your car RHD ? Can you share more pic ?
    May I also ask is the resister for A/C blower fan speed function ? Or that’s for the 2 heater fans ? Thanks in advance
  13. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    That pic of my resistor wiring is for RHD which I believe is exactly opposite to LHD
  14. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Yes my car is RHD , that’s why I thought yours is RHD too
  15. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    I’m away from my car for another week, but if I can help with any specifics , send me a message and I’m happy to send pics, measurements etc
  16. Ferraridoc
    Jun 20, 2012
    17,248
    Gold Coast, Aust.
    Patrick
    That's the resistor winding for the a/c blower fan - it's mounted on the LHS, bolted through the fibreglass panel above the evaporator. If you use the search function, you will find lots of pics for the heater hose routing.
