Need a new battery for my CS | FerrariChat
Discussion in '360/430' started by SURF, Jan 31, 2013.
  1. SURF
    SURF Guest
    Nov 6, 2004
    47
    North Hampton,NH.
    The dealer wants big $ for a new battery in my CS. Any suggestions on what to replace it with?
    Surf
  2. euro_king
    euro_king Formula Junior
    Mar 18, 2009
    759
    San Jose, Jakarta
    Jastien Weiss
    interstate mtp91 should be around 100$
  3. CAracer
    CAracer Karting
    Oct 26, 2012
    228
    Pflugerville, Texas
    John Blanor
    I just bought the same battery and it's more than a $100 more like $134 after you return the core. Good luck
  4. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    I switch to Interstate every time I replace a battery.
  5. F1.360.LOVER
    F1.360.LOVER Formula Junior
    Dec 12, 2009
    476
    Central Florida
    Nate
    I just got a Bosch a couple of weeks ago. Perfect fit.
    Nate
  6. Alesnik-MD
    Alesnik-MD Formula Junior
    Aug 28, 2006
    453
    West coast FL
    JPA, MD
  7. donho
    donho Karting
    Oct 11, 2006
    154
    Naples, FL
    Michael
    The Interstate MTP-91 is sold at Costco for $73 under a generic Interstate label.
  8. arizonaitalian
    arizonaitalian Two Time F1 World Champ
    Oct 29, 2010
    20,507
    Wyoming
    Get the interstate for ~$100. My dealer service guys actually told me to get one at the local Napa (or whatever) and they drove to my house and istalled it. They did the same for the battery tender. Now that I think about it they did the same with my tires. Bought all those parts at the local parts place/online (for the tires). Dealer installed for min $. Love my dealer.
    I'll never forget when I had to replace the battery in my (IRCC) Maserati (happened before I had the Ferrari). Called AAA and they came out and wanted $170 for the interstate installed in my garage. I said "gee, that a lot, let me check with the dealer". So I called the Ferrari/Maserati dealer. They said "its $400 here". Yikes! I then called Kragen and they wanted IIRC $110 or so. I told the AAA guy to go ahead for the $170 installed right then. Anyways, next time it happened was with the Ferrari and I had learned...just went to the parts place and brough it home to meet the Ferrari tech at my driveway.
  9. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    364
    So. Cal
    Joe
    I replaced the battery in my CS with an Optima and it has been great. Same as the battery in the Scuderia. Saves weight and less acid concerns. Both are great cars.
  10. tazandjan
    39,170
    The Odyssey PC 925 has way less cold cranking capability than the OEM FIAMM or the Interstate MTP-91. I would never go with an under-powered battery for a Ferrari application, even though many owners do it. Too many bad things can happen when a battery is undersized. There are better Odysseys with better cold cranking capability, but they are expensive.
    Battery prices have risen pretty steeply in the last 18 months or so. Metal prices have gone through the roof.
    If you fit an MTP-91 like the one in my car, make sure and fit the vent hose.
    Joe- Ferrari had reliabilty problems with the Optimas and stopped using them. Not sure how the new ones are doing.
  11. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    I'm in the Chicago area and the Costco's don't seem to carry this. Do you have an item# or more detailed description? I asked for anything with "91" in it but they do not stock anything.
    I've also found the MTP-91's to be closer to $130-$150 in my area, and most Dealers
    I've contacted from the Interstate website are no longer dealers or don't keep that size in stock, strange.
  12. RichardCH
    RichardCH F1 Rookie
    4,661
    I find the 997 GT3 RS battery is the best and relatively cheap too, have it in my 2 Ferraris and highly modded 996 TT
  13. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Why what can go wrong ?
  14. tazandjan
    39,170
    Rick- Not enough cranking power. Much less reserve power. Especially critical for Ferraris that are not not driven often. Not recommended by Odyssey for that application. They recommend the 34R-PC1500 for the Ferrari 360 and other Ferraris.
    Other than that, nothing.
  15. ferrari355gtb
    Nov 3, 2003
    1,600
    R
    There's considerable weight saving from them though - 10kg (?). And if left on a trickle should be ok ?
  16. skokjef
    skokjef Karting
    Jul 16, 2004
    71
    SURF, you pick up another CS?
    I recently replaced my battery in the CS and wanted a dry cell. Put a DEKA 9A34R AGM in and it fit fine. Has worked like a charm ever since.
  17. donho
    donho Karting
    Oct 11, 2006
    154
    Naples, FL
    Michael
    #17 donho, Feb 2, 2013
    Costco's item number is 517999. The vent is in the middle and the fit is perfect for a 360.
  18. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    Awesome, thanks!
  19. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    be aware that AGM batteries, as good as they are, are designed for constant heavy use, they will fail as fast or faster than a std "wet" battery if left in a discharged state for a length of time... that is their weak point... being left discharged or low charge levels... charging systems not designed for AGM batteries also may not get them fully charged... AGM use a different voltage and has a preferred charge profile to get them to 100%
  20. tazandjan
    39,170
    AGM batteries can be deep discharged dozens of times without losing their ability to be recharged, unlike normal wet cell batteries. They do, however require a really heavy duty charger if they are discharged to around 80% and may seem dead to the layman.
  21. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Hum.... Not good to hear this about AGM's as today I just shelled out $165 clams for a Sears Diehard Gold AGM battery in the 48 group size.......
    I mainly got the AGM due to implied to be safer in an accident, or less chance of spills, and no venting of gases. 3 year replacement - so if it dies- get a new one.
    I am adding a trickle charger - Battery Tender, and on it 24/7.......
  22. awatkins
    awatkins Formula Junior
    Apr 10, 2005
    396
    SFO Peninsula
    Alan Watkins
    I wouldn't feel any remorse if I were you; AGMs are great for all the reasons you cite and they don't particularly require special handling. They're used in lots of normal automotive and marine charging environments. I bought a Powermaster for my race car and they recommended a schumacher charger like this one
    Schumacher SC-1200A SpeedCharge 12/8/2 Amp Charger/Maintainer/Starter/Tester : Amazon.com : Automotive
    so out of shear perfectionism I bought it since it has an AGM switch setting and was cheap to boot. But the fact is that most of the time it's being charged by a perfectly ordinary alternator and it's perfectly happy.
  23. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    it's not about deep discharging the AGM battery, that is where they shine, what they don't like is being left in a state of deep discharge, that is where they go wrong... in applications where they are deep discharged they are brought back to full charge immediately after being exhausted and have a long useful life... typically a std wet cell battery can go though 250-300 charge cycles, while an AGM can easily double or triple that before needing attention
    AGM batteries have a preferred charge cycle profile which controls charge voltage and temperature which can be had only for a charge system designed for the AGM, a std 12v charge system will not allow the AGM to be used at its' optimum
