Need a new lift for my garage. | FerrariChat
Discussion in 'Technical Q&A' started by dersark_painclinic, May 8, 2018.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    I am in the process of purchasing a new lift for my garage. I came across two different lifts by BendPak. Both are in the same price range. The MDS -6LP which has very versatile appearance and does not occupy any space, raise 46". The other one is a Image Unavailable, Please Login Image Unavailable, Please Login 2 lift which occupies a lot of space in a ordinary residential garage.
    The MDS-6LP uses compress air to lower but the 2 lift does not. Any professional advice appreciated.
  2. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    What kind of base do you have for bolting down a 2 post lift? And what work do you intend to do - in terms of the lift height you need?
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    I use the md6xp for midlift ..works well for rear engine vehicles but not good for exhaust work and transmission work on front engine work
    Sent from my Moto G (4) using Tapatalk
  4. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Flash, on the mid engine V8s (308/mondi - 355 etc) would this let you clear an engine out - assuming you dropped the exhaust, maybe took the wheels off, so the subframe was on a low trolley?
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    It is a residential garage, assuming 4" concert. working on my Ferrari and other cars. I do not have high ceilings
  6. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I just sold my MD-6 XP, I need one with open center like MDS-6LP
  7. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Mine is 550
  8. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Op,
    Not sure what you’re US regulations are, but I’d look at someone like eagle equipment in terms of the base spec. You might find your post lift needs additional foundation work because of the depth and also type of concrete used. Not insurmountable, but it adds to the cost / value for money piece.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    I can't say for sure ..it does work well on a testarossa ..thinking if works there it should work well on 355 etc
    Go to the bendpak website and pull the installation manual ..it will show you the dimensions ...that should help
    I would think it is the good mid rise lift for all our r mid engine cars but only saw it really used to take the engine out of the TR ...
  10. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Flash,
    As you say, if it can handle a TR then it should make light work of the V8s. A pro 2 post is great, but sometimes the prep work, maintenance and warranty doesn’t always work out unless you plan to use it a lot, have a mobile mechanic, etc. Thanks for the info - should help the OP too - sorry to semi hi-jack thread...
  11. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    The reviewed the manual instruction and will work for me, The company is not to far from where I live, I may stop by this Saturday to see if they have one on display. I am more interested in the MDS-6Lp one. It is not on your way.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    I would say the jack I am speaking about may not be best for 550 etc
  13. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    flash32, which one are you addressing to.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    The md6xp
  15. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I used that for over 10 years, very solid lift requires no maintenance but some annual greasing. The main problem is you can not have access to the center of car, for that reason I sold it.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    I will just throw this out to you ..have you looked at the max jack..I am not endorsing it or recommending it
    .just wanted to ensure you looked at it
  17. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Flash32, yes , I looked at the product very carefully, Costco used to sell but they discontinued, Their are ones on this forum which has the lift. price wise very impressive, but honestly I can not convince myself as a safe product. But I hope it is for others.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,073
    Central NJ
    Dominick
    That was the same conclusion I came to when I bot the 6xp ..[emoji106]
  19. Qavion
    Qavion F1 World Champ
    14,503
    Ian Riddell
    Does the two post lift require a special voltage (e.g. 3 phase)?
  20. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Sark,
    I have a twin post. Even with a twin it is hard to get the undertrays off. With a midrise rocker panel grabber it will be near impossible...conveniently. Go with the twin. 4" will be fine for our cars. We are far from doing industrial work in our garages. You can hire a hydralic company to set up and install the lift. It is really heavy. Don't even think about picking this up at the local trucking company. Don't even think about installing it with your friends.
  21. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Some of them comes in 110 and 220, and others only 220
  22. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Hello FBB, I agree with you we are not youngsters any more. Getting under cars is not easy any more. Even though I am not a mechanics but I get gellus when I see them standing comfortably and working undernite the car. The 2 post lift requires bigger space, the MDS-6LP does not occupy any space and gives 46 inches raise and that is the maximum my garage celling allowes with beams acros. The other assurance that lift gives me is the wide platform which the car is sitting on it and has no chance to slip over with the horrible pictures I seen. As far as shipping goes friend of mine has truck with tailgate lift to down load the lift inside the garage. That is how we did with Md-6xp which was 1000 pounds. Probably This would be my last service , wondering it is worth to invest $3000 or let local Ferrari does it.
  23. Qavion
    14,503
    Ian Riddell
    I don't know if it's the same for the USA, but larger homes and businesses here can have 3 phase power. Three phase is better for powering large motors and other heavy loads. You don't want your lift to blow your fuses. I have single phase in my garage and it seems to manage my very low rise Quickjack BL-5000SLX, but that is converting electric power to hydraulic power. Some of these lifts are using electricity directly.
  24. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,332
    Atlanta, GA
    Steve D.
    The costco ones are discontinued entirely. Danmar has replaced it with an ALI certified model.
    https://www.maxjaxusa.com/dannmar-m-6-certified.html
    sjd
  25. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
