Need ABS/ASR HYDRAULIC UNIT/ECU F430 | FerrariChat
Discussion in '360/430' started by Jose360Modena, Dec 31, 2019.
  1. Jose360Modena
    Jose360Modena Rookie
    Nov 30, 2018
    20
    Jose Flores
    #1 Jose360Modena, Dec 31, 2019
    Hello and Happy NEW YEAR !!! I recently purchased my 2005 Ferrari F430 f1 with 17,297 miles. From Independent Exotic Dealer in West Palm Beach Florida . It was purchased sight unseen . Anyhow the car is awesome , clean title ,very clean inside and out and I am very Happy with the purchased and Priced I paid no regrets !! But it has a issues and its in the brake system . My brake pedal feels soft and fades . The dealer took it to his independent repair shop in his area that works on high end and super cars . It was diagnosed that brake fluid had excessive moisture ,fluid oxidized creating sludge and paraffin build up ! So I assume brake fluid was never flush on my car ! .They remove master cylinder reservoir performed complete brake system flush , there is no fluid coming out of the left rear caliper ,they disconnect the flexible hose to caliper and found no fluid . They follow the line connection at the steel line no fluid from steel line .They disconnect the steel line from abs pump no fluid coming out of the ABS pump so they suspect ABS pump clogged/seized ..I am having trouble finding it no luck ! Cause the ABS pump is discontinued from Ferrari and the online stores. The part number is 194608 . I can try to unclogged it by dipping in transmission fluid or some other advise ?
  2. RedNeck
    RedNeck F1 World Champ
    12,249
    The CSA
    Me
    This is somewhat common, I believe the units can be rebuilt.
  3. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    It's a ubiquitous Bosch ESP unit. If I were in your position then I would swap the electronics module (which contains the Ferrari specific coding) onto a working valve/solenoid block from a working unit of the same generation.
    A non-Ferrari unit could be picked up for less than $30.
  4. RedNeck
    12,249
    The CSA
    Me
  5. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
  6. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
    I am in Florida USA where you think I can get a non working Ferrari ABS unit for under $30
  7. Jose360Modena
    Nov 30, 2018
    20
    Jose Flores
  8. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,773
    It doesn't need to be a Ferrari unit; that's the point. The unit/module/pump was fitted to everything from cheap city cars to Ferraris. All you need is a working valve/solenoid body. From memory the F430 uses the Bosch 5.3 ESP unit.
  9. janika
    janika Rookie
    Feb 2, 2021
    1
    Jan Halasz
    @Jose360Modena , were you able to get a solution for the ABS problem you had? I have a similar issue and need a new ABS module/ pump. Thanks!
  10. PPW
    PPW Karting
    Oct 4, 2019
    132
    Bump, same here.
    what is a part number that will work?
  11. LorenzoR
    LorenzoR F1 Rookie
    Did any one ever find a replacement unit for this issue
  12. stradalespider
    stradalespider Karting
    BANNED Rossa Subscribed
    Dec 1, 2007
    120
    Can someone post a photo of the front of 194608? I think I may have found a used one.
  13. Califa
    Califa Rookie
    Nov 19, 2024
    1
    califa eisa
    is anybody can help me to find ABS pump unit part number 265225383 for F430 , 2006
  14. Fastf430
    Fastf430 Rookie
    Dec 12, 2010
    13
    Fort lauderdale
    Jay Motwani
    Hello Fellow F430 members! My f430 is down due to a clogged hydraulic circuit on my abs pump. It’s the right front circuit that is clogged. Does anyone know where I can get a new or rebuilt pump. The electronic component is fine?
  15. LorenzoR
    LorenzoR F1 Rookie
    Jay, Try eurospares or ferrparts. Also id be interested in your old one.
  16. Ricambi America
    Sponsor Owner
  17. Fastf430
    Fastf430 Rookie
    Dec 12, 2010
    13
    Fort lauderdale
    Jay Motwani
    Thank you.
