Need Advice on 355. GTS F1 | FerrariChat
Discussion in '348/355' started by Rgio74, Oct 2, 2013.
  1. Rgio74
    Rgio74 Rookie
    Jan 14, 2013
    38
    PA/NJ
    RGio74
    I am in the process of purchasing a 98 355 GTS F1. The car had a major service done in 2007 and since then had 1300 miles put on it. Currently has 17k+ miles. The dealer is telling me it needs a header replacement but not an engine out major service. He detected a ticking sound and said one of the heads had a leak. I could weld or replace. Some questions I have are since the last major was done in 2007 and its past its 5 years what's the consensus on major service? Is it based on yrs or mileage? Also, with the headers leaking is there any other potential damage to the motor block? If I pull the trigger on the car I most likely will replace the headers. Any help Appreciated since this is my first Ferrari!
    Thanks Much!!!
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I own a 98 F1 GTS.
    Ferrari now states cam belts every 3 years regardless of miles, however most dealers will tell you 4-5 years is fine.
    The car does need a major, no doubt at all. I suggest you insist that it be done as part of the purchase and be sure a reputable shop will do the work.
    Be sure to insist on a compression and leak down test as well as a fix to any and all issues found when the motor is out.
  3. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    I agree with all above. Where are you located.. If in the North East Contact John Tirrell @ IFS (Independent Ferrari Svcs).
