I took Paul’s advice on this and I’m very pleased. The engine burns pure and you can really feel the response improve. Most importantly, it can sit for periods of time.
Awesome ! The main thing to know about this motor is that it's an interference design. So if the timing belts break, or shed teeth, the valves will become bent or worse. In addition to the timing belts, make sure that the idler bearings are in good shape. Hill Engineering makes some decent replacements. I believe the current recommendation from Ferrari is 3 years on the belts. I believe the belt manufacturer does not recommend more than 7 years on the belts. Having the engine in the proper place makes servicing more difficult. Much effort and patience are required. Those Fram oil filters collapse. Replace it ASAP. I like the Baldwin filters. Ferrari dealer markup on parts is just shy of criminal. Fortunately, most of the parts can be had from the component manufacturers. Lots of Bosch parts, Stabilus, Veglia,SK, Bendix Italia, etc.
I found these markings on the left rear frame rail. Anyone have any info on what the number relates to? Image Unavailable, Please Login
So today I tested the functionality of every system on the car, except the engine/transmission, and all is in perfect working order. After a thorough inspection of the car today I have found a few things: I am missing the battery hold down clamp (previous owner is looking for it) I am missing all the manuals/books for the car (previous owner is looking for them) The engine cover struts are too weak to hold the cover up Front tires are the ones it left the factory with and the rears are dated 2013. All of them are Goodyear Eagle ZR The shift lever and gate have some wear on them, the shift knob has some cracking in it Right foglight clear glass lens has a crack in it Would like to find the correct material to recover the removable top if I decide to do so Any recommendations on parts suppliers and/or the parts themselves would be appreciated!
The markings are not on the frame rail, but on the suspension wishbone ("A-arm" in american parlance, usually); euro cars do also have markings on "A-arms" at all fours corners (but they say "euro", although these markings tend to disappear after about 20.000 or so. See the ones on the front lower right wishbone (sorry, "A arm"...), upper side, on my # 80515 the first day after I bought her; the pressure pliers were left "in situ" by someone...markings say "EUR F 106". Rgds Image Unavailable, Please Login
The original struts were made by Stabilus. You can buy them here: https://www.liftsupportsdepot.com/shopby/1989/ferrari/328-gts/quattrovalvole-coupe-2door/
The last guy that asked me what I paid for it was driving a 2018 Chrysler Pacifica and I told him he paid more for his minivan than I did for my Ferrari. I smiled, he did not.
While much better than steel, the tanks can rust. See post #28 in the Driver's Side Gas Tank Removal thread. If water sat in the bottom a long time, it can rust out the steel screen pickup, sender unit, and even perforate the tank. In my case, fuel started seeping through the tank bottom and PO's shop went through a few fuel pumps which we deduced later on was caused by the rust particles settled in the tank.
On the targa material, I sourced a 2-yard roll for my QV from Matteo Jones of Re-originals. Yours is the brown (tan)/white pinstripe which might be carried by others. Mine was the red-white pinstripe which seemed "NLA" until Matteo sourced a roll of near-perfect fabric in Italy. Two yards means I have enough left over if I ever want to replace the rest of the fabric around the rear windows.
So it has been a while since I have posted on my project as my car has been patiently awaiting a new set of belts so the engine can come to life again. I am lucky to have 2 Ferrari dealers to choose from by me and have been in contact with both of them, Continental Ferrari of Hinsdale, IL and Ferrari of Lake Forest, IL. The previous major service on the car was done at the Lake Forest dealer. Anyone on here have any recommendations / reviews on either of these two dealers as I need to choose which one will do the major service on it.
I would recommend you post a thread on the IL regional section asking about the best independent technicians in your area that have deep experience with cars from the 80's and 90's. You're better off building a relationship with someone who knows the older cars rather than the younger dealer techs who are more focused on the modern cars.
My friend Mike has his race cars serviced at Continental, I have never heard anything bad about them.
