Need Advice | FerrariChat
Need Advice
Discussion in '360/430' started by trialman1, Aug 9, 2009.
  1. trialman1
    trialman1 Karting
    Oct 18, 2008
    72
    new york
    steven
    I have a 2000 360 MT which i purchased last august from the dealer who did the service before i picked it up. I've put about 1,200 miles on it. Do i need to do a full yearly service or just an oil change and top off the fluids? Thanks,
  2. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    When I had my 360 & CS, I just did the oil change and checked all fluids. I'm assuming that by what you said that your car is completely up to snuff as far as services are concerned? Since your car is MY 2000, when was your last belt service? It looks like if it's on a normal schedule it might be due soon?
  3. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    #3 Ingpr, Aug 9, 2009
    When I bought my 360 I took it to the dealership to get a check out. They only charge me two man hours. When they finish with the car I foud out that I need a belt change, a new clutch and some other parts. But I the end you will see all your car really need.
  4. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,175
    Wash DC area
    Robert
    In addition to oil change you may consider brake fluid, depending on mileage and driving conditions. Have you ever had your gear box fluid changed?? Thats a biggie and make sure the remove the bumper and clean the filter screen. The screen cand and will collect deposits and has caused some transmissions to sieze.
    Like others have mentioned, being a 2000 I hope belt service has been performed at some point in the last 3 years, if not, get it done.
  5. trialman1
    trialman1 Karting
    Oct 18, 2008
    72
    new york
    steven
    Belt Service was done when i purchased the car a year ago. The car was in the dealer a month or so ago to adjust the gearbox and replace the clutch pan. They went over the car and the pan was the only issue they found. Thanks for the advice.
