Need an oem F355 rear wheel | FerrariChat
Discussion in '348/355' started by f355spider, Jun 13, 2011.
  1. f355spider
    f355spider F1 World Champ
    18,055
    #1 f355spider, Jun 13, 2011
    One of mine has some small vertical cracks in the inside lip, discovered during a complimentary pre-drive inspection performed by Ferrari of Seattle. I checked Ebay and Ferrariads, no luck yet. New is an option, but $2200.
    Thanks,
    Dave
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,710
    South East
    Jimmie
    #3 greyboxer, Jun 13, 2011
    Buy & ship a set of four from the uK for that : Ebay Item number: 310320292057
    There's often others on European Ebay eg Item number: 380344592154
  3. f355spider
    18,055
    Thanks, but then add refurbishment/refinishing costs, and I still need to ensure they don't have the same type of damage...
    I appreciate the consideration, just need one, and in good condition.
  4. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
  5. Future ferrari collector
    Oct 12, 2006
    1,795
    Try Eurospares.co.uk. They could have a good used one from the wreaked cars.
  6. WATSON
    23,933
    WI
    Who knows? I know nothing of the seller, the part, or price.....just saw it floating out there.
    Might be junk....might not.
    Hopefully a trusted source on this forum can offer up a better solution.
  7. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Got a front one for sure but let me check for a rear one. In California may be able to help you with a decent deal.
  8. f355spider
    18,055
    Thanks Steve! PM sent. :)
  9. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Could you post a picture of the vertical cracks?
    I've got a stripped wheel that needs to be refinished if all else fails.
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    Ive got a decent rear. PM me if you are interested.
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    You ougfht to be able to buy a used complete set for less than $2K. That's 4 wheels. Bolts might be extra, but you probably don't need them.
  12. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,180
    Australia
    Paolo
    for sure
    there are plenty around
  13. f355spider
    18,055
    PM sent.
  14. f355spider
    18,055
    I don't need a set, nor do I wish to buy them and sit on them trying to resell the ones I don't have any use for. One wheel for $600 or there about is a fair enough deal for me if the condition is good, and does not require refinishing.
  15. f355spider
    18,055
    #16 f355spider, Jun 16, 2011
    Sure Bruce, picture attached. It appears there is some curb damage, and it looks really old. I image it occurred a long time, ago, maybe prior to my ownership. The cracks may have appeared more recently, though they look old to. I have recently noticed over the past 6 or 7 months that my left rear tire would lose 4lbs of pressure over the course of 5 weeks or so. I performed an oil change a couple weeks ago, and while up in the air, I inspected the tire, no nails, so I suspected a problem with the valve stem. Never thought to look more closely at the wheel, particularly on the inside lip.
    The good folks at Ferrari of Seattle have started offering free inspections to those signed up for FCA overnight drives, and it certainly paid off for me. I will be glad to get this taken care of promptly.
  16. greyboxer
    Dec 8, 2004
    12,710
    South East
    Jimmie
    Guy just listed some on Ebay Item number: 150620091298
  17. Dave Monk
    Dave Monk Karting
    Apr 23, 2010
    213
    SW Virginia
    David Monk
    If it were mine I would remove the tire and check the crack propagation. I can't imagine what stress load caused those cracks other than the rim rash. IF the cracks are a result of that just tig weld them up, smooth everything back down and use the wheel you have. If the cracks are worse than they look on the outside, or you see others then I would replace the wheel. Just my cheap 2Cents worth...
