Need an urgent hint or tip with 430 Handbrake Caliper! | FerrariChat
Discussion in 'Technical Q&A' started by Aaronholmes220, Mar 18, 2014.
  1. Aaronholmes220
    Aaronholmes220 Karting
    Dec 12, 2009
    121
    County Durham UK
    Aaron Holmes
    #1 Aaronholmes220, Mar 18, 2014
    Having a nightmare here lads, fitted new discs all round and the handbrake caliper hates me.
    After finally getting the cable free (workshop manual says to simply "remove"...yeah of course...) and removing the caliper, now I have a new full thickness disc and obviously the piston needs to be retracted... but how do I do this!? the spring is at it's full extension and the piston looks as though it has some travel left although I don't want to force it as I don't know what I'm displacing by doing so.
    Car is in bits right now any help would be majorly appreciated!
  2. Aaronholmes220
    Dec 12, 2009
    121
    County Durham UK
    Aaron Holmes
    #2 Aaronholmes220, Mar 18, 2014
    Well luckily a bit of thinking time later and I cleaned up the face of the piston and found two locating holes. using circlip pliers you can rotate the piston and it winds in clockwise.
    Problem solved.
  3. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Yep, you got it. If you don't have circlip pliers handy, a pair of needle nose pliers works as well.
  4. Aaronholmes220
    Dec 12, 2009
    121
    County Durham UK
    Aaron Holmes
    Got a new problem now.... The handbrake cable was adjusted for the old discs which were worn, so now I can't reattach the cable because it's too tight!! and the entire undertray has to be removed to get to the adjuster!!! So sick of this job already...
