Just got a 360 CS. Need suggestions on how to: clean the dirt buildup around the edge of the clear plastic tape around the wheel wells. what cleaners to use for the lexan...my dealer said mirrorglaze???
I find that a 50/50 mix of alcohol and water helps remove oxidation and dirt build up in the clear plastic covering on the wheel wells. After that, I go about a normal waxing routine (prewax cleanser then wax) and remove any trap wax with a microfiber towel to avoid excessive marring of the finish. Hope this helps.
