Need clear lexan engine cover replacement for F8 Tributo Coupe | FerrariChat
Discussion in 'Technical Q&A' started by EyeGuy, Apr 24, 2020.
  1. EyeGuy
    EyeGuy Rookie
    Jan 7, 2020
    3
    Silicon Valley, CA
    Dan Baggett
    I have driven the demo F8 Tributo twice (I have one on order), and have been VERY unhappy with the visibility out the back of the ridiculous slotted lexan engine cover. It has cutout slots that cause SIGNIFICANT distortion and multiple images. In addition, the cover vibrates right in the center, surrounding one of the cutouts. Many others who have driven the demos have mentioned the same visual problems with the cover.
    I have been unable to get Ferrari to consider an easy fix as an option: a clear lexan cover - exactly the same dimensions, but without the cutouts. I have even said that I would pay a significant amount as an option. There should be plenty of time to do this, as the factory is essentially shut down, but designers could still be working normally. There is no reason they couldn't easily do this, as the molding process would be identical, merely removing the molds that create the cutout slots. Again, they could care less it seems.
    Does anyone know of a manufacturer that could make me a replacement once I take delivery?
    jahdish and psych0hans like this.
  2. NuorderSG
    NuorderSG Formula Junior
    You probably won't get Ferrari to do a one-off design unless you are an Oil Shiek, Russian Oligarch, or such. ...or have a personal relationship with someone who has some pull there.
    You may be able to mitigate the visibility issues by applying a tinted film to the " louvers." ...or if it is just the cutouts, try to de-gloss the cutouts. Experiment with painters tape at the "cutouts" to determine what areas need to be modified.
    I had an old Transam with glossy louvers and they just distorted my rear vision. I bead blasted the glossiness away from the "cutouts" and problem Solved. ... even some extra fine grit wet-sandpaper wrapped around a painter's stick may do the trick if you are patient and very detailed. If u screw up, you can always polish away small mistakes.
    Re: the vibrations, a film may help if it is a harmonic distortion. Though, if it is rattle from poor fit, some thin rubber shims may help at attachment points or where is metal contact.
    ...just some thoughts.....
    greg328 and psych0hans like this.
  3. RaceMX-M3
    RaceMX-M3 Formula Junior
    Dec 15, 2010
    540
    Frisco, TX
    Scott
    Wonder if the glass from a 488 might be the same shape? or another model? Just a thought. I wasn't crazy about the louvered glass the first time I saw the car either. I'd say chances are the part is outsourced to a vendor but could be wrong.
  4. absostone
    absostone F1 World Champ
    10,043
    Arent the slots to release engine heat?
  5. jahdish
    jahdish Karting
    Aug 9, 2004
    111
    tampa, fl
    Paul Dziadosz
    Any luck on options to fix the rear visibility issues?
