355 - Need electric diagrams | FerrariChat
355 Need electric diagrams
Discussion in '348/355' started by jvillarreal, Feb 24, 2024.
  1. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    juan villarreal lois
    Hi, i´m newby and i´m restoring a 355 berlinetta manual gearbox, 1995. i have the front wires for lights,etc... but cut wires on the fusebox and no connectors, i need the electric diagrams to see we,re goes the wires of the lifting motors. if anyone can help, thanks.
  2. Qavion
    Qavion F1 World Champ
    14,260
    Ian Riddell
    Do you have a North American car?
    Which fusebox? Front luggage compartment or passenger footwell?
  3. Qavion
    14,260
    Ian Riddell
  4. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    hi, sorry for late reply, european, the fuse box on front luggage.
    thanks for the info added.
  5. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    i checked the info you pass me and is all i need for that problem. i check on car tomorrow and tell you if all works well.
    can you upload for me the complete 355 berlinetta manual, repair, etc...? thanks for all.
  6. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    one question if you can help me, when i switch fog lights, the front and the rear glow at the same time? because only one switch, no?
  7. Qavion
    14,260
    Ian Riddell
    #7 Qavion, Feb 24, 2024
    Sorry, they are too big (for me) to upload.
    On most Euro cars, only the rear should illuminate. On US cars, only the front fog should illuminate. The logos on the switches point in different directions on these cars. I think there should be two switches if both illuminate. The fog light symbols on the instrument panel should also be different.
    To faciliatate the front fog on a USA car, an additional relay is fitted (Relay G)... and a lot of extra wiring. I can't explain what you're seeing. The fog lights on USA cars
    By the way, did you change any relays? e.g. relay E is a double pole relay on a USA car (single pole on a Euro car).
  8. Qavion
    14,260
    Ian Riddell
    The front fog on USA cars requires the position lights to be on (first switch position). The rear fog on Euro cars requires the low beam headlights to be on (second switch position).
    jvillarreal likes this.
  9. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    yes when low beams are on on my car, i have only 1 switch, and when on, the rear light on, but my dude is for the front?, when that front fog goes on? that´s dude is because my front wiring harness are cut.
  10. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    finally for the fog lights i find that i want on diagram you give to me. no front fog light, there´s a daytime flashing light. thanks for all, the electric diagram help me a lot men.
    Qavion likes this.
