Need Floor Jack Recommendation | FerrariChat
Discussion in 'Technical Q&A' started by Chicane, Dec 15, 2007.
  1. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    What kind of low profile floor jacks are you guys using for your cars? What is the quality?
  2. RayJohns
    RayJohns F1 Veteran
    7,941
    West Coast
    Ray
    check ebay, sears, amazon.com or costco, etc. There are a lot of nice low profile floor jacks around. Here is a very high quality one that I'm looking into. I am not sure if I will get one of these, or two of some of the more common types floating around.
    http://www.ac-hydraulic.com/
    Ray
  3. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    I recently got the 3 ton Magic Lift jack:
    http://www.alltiresupply.com/p-OME-25037.html
    It has a low, 4 inch height, is broad, stable and heavy and instantly gets to the first contact height in one pump of the bar. Many places sell it and you can get it for less. As always, when you get the object up to the working height, use a jack stand before getting under anything.
    aehaas
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
  5. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
  6. f355spider
    f355spider F1 World Champ
    18,055
    Similar one sells at Coscto, only much lighter at 26lb weight, and similar low height. BUT, only goes to 14.75" high, and lifts 3,000lbs. The reason people prefer it, only $100 and comes with Coscto's lifetime warranty. If it breaks, you can return it to any Coscto for a full refund.
    As others said, there are many quality jacks out there and the HF ones seem to be a popular choice. I am using the Griot's Garage low profile jack, works great, and goes very low, which is mandatory for my 355.
    http://www.griotsgarage.com/product/in+your+garage/jacks+%26+stands/2-ton+floor+jack.do
    Lifts 4000lbs, and go as low as 2.25" and as high as 20". Side pedal allows you to lift the saddle up to the lifting point quickly.
  7. f355spider
    18,055
  8. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    45 lbs. I'm just sliding it around the garage floor so I am not concerned with that. Plus I need a 4000 lbs jack not a 3000 lbs jack. HF sells a 3K:
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40105
    This thing is rock solid and an even lower profile than the 3K aluminum jack that I already have. For $150 you can't beat this. And it comes with a one year warranty.
  9. f355spider
    18,055
    I was pointing out the weight issue to another poster "Meister" who must carry his in/out of his car, or so he implied.
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I think I was wrong...I was in the actual Northern tool store the other day, and the one I bought was $79, not the $100+ in the link.
    All I know is that the aluminium one I bought jacks the Lotus, Ferrari, vettes, etc.... It's less than 30#'s, and does a fine job.
    Sorry for the incorrect link.
  11. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
  12. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I was going to pick up another Craftsman aluminum / steel race jack (about $149), then saw a Torin Black Jack at Walmart - seemed decent, very low (3.3"), good weight capacity (6000 lbs), and decent lift height (17+")...and only $68. No experience with it yet, hopefully does well next week during my major!
  13. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
  14. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
  15. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    Did you check out my post above?
  16. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    I have that Costco jack and while doing my brakes and headlights I had the car on stands. I noticed a puddle of oil under the jack when I went to jack the car up to remove the stands. That damn thing is leaking oil through its seals. I don't think I'm going to cheap out on the next jack. It's not worth the risk.
  17. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Harbor Freight. I got the less expensive aluminum racing jack on sale for $79. It works just fine. The more expensive one is the fast pump model, but the less expensive one seems to do the job, it's lightweight, I take it to the track and use it around the garage, no problem. And it's rated for 3 tons. Just fine, IMHO.
  18. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    Is the same one that is now $150?
  19. Prova7
    Prova7 Formula Junior
    Nov 17, 2003
    257
    Dallas, TX
    DamonB
    I'll second these. The only jack you need to know about. You can buy them from Pelican Parts and others.
  20. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
  21. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    I have the DK20 floor jack from AC. Great performance and quality, though expensive (about $500. as I recall), purchase through ultimategarage.com.
  22. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    Yup.
  23. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Don't cheap out on a jack... These AC's are worth the money.
