need garage dimensions for a lift | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by garysp7, Feb 10, 2005.
  1. garysp7
    garysp7 Formula Junior
    Mar 28, 2004
    436
    Florida
    Gary
    Can any of you tell me how high you have built your garage ceilings when placing a lift inside. Also, how high are you rasing your garage door when it is up. Do you place an extra set of door tracks to raise it up against the raised ceiling?
  2. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Autolifters
    I am using the M6, 4 post. Movable from bay to bay. Commercial grade. Nicely built, good design. Made in USA.
    They provide dimensions and required clearances here. Measure the height of your car, add to the "full up" dimension of the ramp, add a foot.
    http://www.autolifters.com/images/m6SideView.jpg
    and here,
    http://www.autolifters.com/images/m6TopView.jpg
    For a two post,
    http://www.autolifters.com/8000_lp.html
    They explain pretty much all of the space requirenments.
    I have found that I can get away with about 18" less recommended overhead clearance with my 308 as long as the rear hatch is closed.
  3. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Okay, a 10 foot ceiling is a good start. If you have a pitched ceiling you might want to run the doors up the pitch. It helps in tight situations.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Mine is 12' and I run the garage door about 6" below the ceiling.
  5. drew365
    drew365 Formula Junior
    Jun 22, 2004
    252
    The Valley, L.A.
    Andy Ritter
    My garage ceiling is 9'4". I have a two post lift and that is the minimum needed for my lift. I can get my 365GT up on the lift and pull my Porsche under it with no problem. I did have to have the garage door tracks raised up.
  6. ultgar
    ultgar Karting
    Nov 21, 2003
    126
    New Jersey
    Steve D'Gerolamo
    Technically, you need approx 72-75" (the max lift height of your lift) + the height of your tallest car ....... but unless your ceiling height can accomodate the height of your posts without getting into some reframing, the post height is often the limiting factor in residential garages.
    As far as width.......its often 12-15' (20' is best). As far as length, unless you've got a Maybach, 22-25' is fine.
    SD
