355 - Need get down engine to install new FHP drive pump ? | FerrariChat
355 Need get down engine to install new FHP drive pump ?
Discussion in '348/355' started by C'dwic, Oct 5, 2022.
  1. C'dwic
    C'dwic Formula Junior
    Apr 23, 2021
    493
    France
    All in tittle, have we all access to install new drive pump without getting down the engine ?
    Have we acces on all screws, bolts, belt ?
    If you have picture or explain, I take all…
  2. Rifledriver
    37,087
    Drive pump? If you are asking about power steering pump yes it is possible but not easy. Far less work than pulling motor but we used to do it regularly to do warranty replacements or put in Challenge pumps.
  3. C'dwic
    Apr 23, 2021
    493
    France
    Yes power steering pump, you right.
    We can remove all screws ?
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    I have done it and like Brian said it's not easy. If you have a spider, it is easier than a coupe.
  5. C'dwic
    Apr 23, 2021
    493
    France
    I have a GTS so same difficulties as coupe you think..
  6. Rifledriver
    37,087
    Same
  7. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    The reason the spider is easier is you can drop the top and remove the engine lid. Then the work can be done while you are standing in the passenger compartment. With the GTS, you have to work from inside the engine bay.
  8. C'dwic
    Apr 23, 2021
    493
    France
    Qavion and johnk... like this.
  9. C'dwic
    Apr 23, 2021
    493
    France
    It’s seems that in the middle of the pump, there is a long screw, so it’s possible to have acces on it ?
  10. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Qavion and C'dwic like this.
