Need help asap please, new clutch installed | FerrariChat
Discussion in '360/430' started by russomanno, Jun 18, 2015.
  1. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Hey guys, just installed a clutch in my 360 F1. Using the navigator txt to change cluctch setting but it's all over the place. Did the self re-learn as well, but I put the car into gear and it automatically jumps into neutral. I don't know what the settings should be at in regards to the clutch configuration and the slipping start position script
  2. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    No matter what I change it to as soon as I let off the brake it goes into neutral
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    O.k let's start from scratch.
    1. What level of TCU do you have.
    2. What clutch thickness do you currently have
    3. What is the pis currently at
    4. Has a full clutch drain been performed
    For what it's worth, I didn't think you could alter clutch thickness with that machine. In fact last time I looked at one it was pretty restricted in some key areas. If that's still the case you are on a hiding to nothing, it'll never work right...
  4. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Rusty can you call me?
  5. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Factory TCU 2002 360 Modena
    Under clutch configuration it's at 13.27mm
    Slipping start position 4.44
  6. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    Clutch drain? Not sure
    It's showing 1% wear. Before I hooked up the computer it was running fine but I found it was slipping quite a bit
  7. russomanno
    russomanno Karting
    Dec 16, 2011
    173
    I got everything to work but after driving the car it resets the values back to -2.23 mm which makes it think it's 220% worn
