Need help bending aftermarket fender shields | FerrariChat
Discussion in '360/430' started by Tony360, Apr 24, 2013.
  1. Tony360
    Tony360 Rookie
    Oct 30, 2012
    20
    Tony
    Picked up a set of aftermarket Ferrari Fender Shields. I can not seem to get them to bend to follow the contour of the fender. Please help me and tell me how to do it.
  2. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    purchase a piece of PVC pipe in the diameter that is closest to the contour and roll the shield around the PVC to meet the contour of the fender. Experiment with a pie tin or other thin metal to gain comfort with the process.
  3. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,524
    Honolulu
    Kevin
    I don't know whats best but I would try to find a guy with a roll former or roll forming equipment.
    It would be something like this:
    12" x 20 Gauge Slip Roll
    You might have to heat up your unit so the paint doesn't crack, possibly in hot water and take it real easy.
  4. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
    On my former 355, I had to bend Yoshi's a little more open (bigger radius). On the first shield, I placed it on a phone book and pressed down on the middle portion. On the second shield, I just bent it open with my fingers. The finger bending method worked better for me. The fit came out perfect. It's a little tough to bend as it springs back, but it should work.
    If you need a smaller radius, I would try bending with your fingers also.
    Good luck!
  5. rob4092xx
    rob4092xx Formula Junior
    Mar 8, 2010
    570
    Phoenix, AZ
    Are the Yoshi's flexible? It sounds like the ones Tony got are not flexible.
  6. yronZFF
    Dec 21, 2009
    749
    FIVE-O
    Ron
    No, Yoshi's are not flexible, but they will bend given enough force.
  7. rob4092xx
    Mar 8, 2010
    570
    Phoenix, AZ
    So how do you bend Yoshi's to get them to perfectly contour the fender???
  8. yronZFF
    Dec 21, 2009
    749
    FIVE-O
    Ron
    Hold in one hand and bend shield with your other hand using your fingers and they will bend. Bend, test fit, if it doesn't fit flush, bend again, test fit again and continue this sequence until the contour is perfect. Many owners with Yoshi's have also done this before me. Once you've done it, you'll understand that it works.
