Need Help Cam Bearing Cap | FerrariChat
Discussion in '308/328' started by manta147, Mar 6, 2016.
  1. manta147
    manta147 Karting
    Sep 7, 2006
    128
    seekonk,mass
    carter petter
    Hi Guys,
    I'm at a loss! Need a cam bearing cap part#115465.It's for the right head,intake cam on a '82 2v 308.Ricambi and Ferrparts can't locate one.Any suggestions????? Don't know what to do.
    Thanks in advance guys.
    Carter
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,461
    Canada
    Newman
    I have a bag of spare caps I bought a year ago to save my butt someday in the future. I might have what you need. Its a full set from one 2V head.
  3. manta147
    manta147 Karting
    Sep 7, 2006
    128
    seekonk,mass
    carter petter
    Newman.....PM sent
  4. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    I bought caps from Eurospares.co.uk when I broke one.
    Peter
  5. mwr4440
    57,969
    Bavaria, The 'Other' Germany
    Mark W.R.
    Peter,
    How did you "break" a cam bearing cap?
    Not trying to be a "dick" just want to make sure I don't do what you did.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    Given that they are cast Al parts, it doesn't take much. the caps use a centering ring on the stud for location, due to the clearance getting them cockeyed is fairly easy, continual tighting will crack them and break them if they are off kilter. The other way it can happen is by the use of shim material that is too thick when trying to hold the cam from turning. One reason I've never been a fan of that method, if they were billet or forged pieces they would handle the stress a lot easier.
  7. mwr4440
    57,969
    Mark W.R.
    Got it.
    Thanx Scott.
    Learned me somtin nu 2day. :)
    I luv me askin stuuuuuupid Kuestions. :D
  8. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    To be technically fair, it's a question of ignorance :) Those are "A OK"...
  9. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
  10. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Will a spare part fit perfectly? Aren't they bored together with the mating head?
    At least this is, what I have in my mind when removing or installing the camshafts. I take my time and loosen or tighten each nut just half a turn one after another.
    Best Regards
    Martin
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    Ideally the bore should be re-cut or reamed. There is a factory tool for such a job, it's a PITA but worth the effort. More then likely the spare cap will not line up correctly. I've had to re-do the bores on heads that once tq'd down had enough warp to need it. PITA job as the heads need to be tq'd down.
  12. Rifledriver
    37,105
    No, may not fit at all and that is why Ferrari only supplies them with the head.
    Yes and that must be done. Most good automotive machine shops are equipped for that. Ferrari did make those tools available to the dealers and I have them but few shops do.
