need help: engine "Tapping Sound" on 360 coupe | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Jimmy540i, Aug 30, 2005.
  1. infraredline
    infraredline Formula 3
    Mar 15, 2004
    1,036
    San Francisco
    I think he meant in the valve lifter. That can happen.
  2. ksanjana
    ksanjana Karting
    Oct 28, 2014
    112
    Houston, TX
    Just out of curiosity, which Mobil 1 oil do you use? is there a specific one for Ferrari's?
  3. BJJ
    BJJ Formula 3
    1,301
    Might it be a problem with one of the cam variators? Is said to be a common problem with the 360. I believe that there was a recall campaigne at some time. Was that done?
    I recall that my QP5, having similar cam variators, started to make a slight tapping noise when they started to go.
    If it is a cam variator, I would suggest immediate repair, because it is said that there have been a number of engine breakdowns due to failing cam variators in the 360. Should be possible to locate by using a hose, with one end at the ear, the other end held near areas of suspect (old method, but very very effective)
  4. muk_yan_jong
    muk_yan_jong Formula Junior
    Oct 11, 2008
    570
    Brian McK
    I really hope this is a joke.
    If you came into my shop with a internet page printout you'd be DNS from that point forward because nothing I'd tell you would ever be correct.
    Take it to the/a shop and have it fixed. There is no other way and ESPECIALLY not thinking you can rev or drive it out. A few hundred metal parts in your engine and each one makes a different noise.
    EDIT - Just processed the last diagnosis... You have GOT to be kidding me...
  5. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    You guys realize that you are replying to a 10 year old thread?
    Sid
