Need Help:F355 Side View Mirror Wiring | FerrariChat
Discussion in 'Technical Q&A' started by rlndhill, Feb 15, 2014.
  1. rlndhill
    rlndhill Rookie
    Feb 15, 2014
    5
    Virginia, USA
    Hi,
    I'm new to forum and I'm having a problem with my P/Side View Mirror. Can anyone provide assistance on what the following wires do?
    Orange
    Blue/Yellow
    Yellow
    Black/Yellow
    Black
    Any assistance is greatly appreciated!
    Robert
  2. tazandjan
    39,159
    Robert- Volume 3 of the F355 workshop manual has color coded wiring diagrams for the mirrors. If you do not have a copy, you can download one for free from ferraridatabase.com. The color codes are spelled out on the first page of the wiring diagrams.
  3. rlndhill
    rlndhill Rookie
    Feb 15, 2014
    5
    Virginia, USA
    Tazandjan,
    I went to their manuals and I didn't see where they spelled out what each wire is for? I'm I missing something? If possible, can you attach what you are talking about?
    Thanks,
    Robert
  4. tazandjan
    39,159
    Robert- Figure 9 in Section L does not tell you what each wire does, it just shows you where they all go. Deciphering wiring diagrams is not one of my strong suits, so you may need professional help.
  5. rlndhill
    rlndhill Rookie
    Feb 15, 2014
    5
    Virginia, USA
    Ok..thanks. :)
  6. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I'm not sure if the 355 has the same issues with the door/body connector plugs. I have repaired my 348 door electrical problems by freeing up the wiring that flexes when the door is opened and closed. This harness was originally installed a little to tight and the harness was pulled and flexed at the plastic plug, eventually breaking off the wires at the plug pins.
  7. rlndhill
    rlndhill Rookie
    Feb 15, 2014
    5
    Virginia, USA
    Thanks, The problem I have is that my mirror will not go up or inward. That's why I'm trying to figure out what each wire does?
    Robert
  8. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    I am sure you have cleaned the switch with contact cleaner. I had the same problem with my old BMW and a squirt of cleaner and working the switch back and forth a bunch has led to resolve all of the contact problems.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    If the mirror works in one direction but not the other, then all the wiring to the mirror is ok. The switch just reverses the current flow to change direction. For up/down operation it is the same thing. I would either take the mirror switch apart and clean the contacts inside or replace it with a new switch.
  10. rlndhill
    rlndhill Rookie
    Feb 15, 2014
    5
    Virginia, USA
    Motob,
    The switch is what I will be buying next. I replaced both of the mirrors and after installing them, that's when the problem started. That's why I need to know what each wire does because the wires coming out of the doors didn't have the plug, so I had to crimp the wires from the mirrors to the wires in the doors.
    Robert
