Need Help finding seat lever for 348 Spider | FerrariChat
Discussion in '348/355' started by Spider Jeff, Jul 14, 2009.
  1. Spider Jeff
    Spider Jeff Rookie
    Oct 9, 2006
    43
    The Woodlands, Texas
    Jeff H
    I managed to break the seat lever on the drivers side of my car. Neither Ricambi or Ferrari Houston has the part, any ideas? I also looked all over the internet, no luck so far.
    The top is about impossible to put up from its current position, without adjusting the seat back rake, with the handle broken. Not a big problem in Houston, where it has been about a hundred for a month, as the AC is weak at best on days like that.
    I suppose I could take to a shop that has CNC capabilities, and get one fabricated from metal, as a last resort?
    I appreciate any help/suggestions.
    Jeff
  2. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
  3. I'm gone
    I'm gone Formula Junior
    Feb 5, 2006
    619
    Phoenix,az
    Brian
    I need one of those also, #38 in the diagram looks like it.
  4. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
  5. Spider Jeff
    Spider Jeff Rookie
    Oct 9, 2006
    43
    Jeff H
    Thanks much, looks like part 38 (63998600), Mike at Ricambi called around for me also, I assume if it is the same as a 355, that lever is also not readily available.
    I appreciate you sending the link, very helpful!
  6. Spider Jeff
    Spider Jeff Rookie
    Oct 9, 2006
    43
    Jeff H
    Thanks Ton, it may work, but would not match the passenger side.....mine has a checkered pattern, that one looks smooth. I guess I need to pay more attention when I look at a 355 to see how close they are, if they fit, maybe buy a LH and RH and be done with it....appreciate the help.
