Need help fixing 458 ctek battery tender dongle | FerrariChat
Discussion in '458 Italia/488/F8' started by DefunctNeurons, Jan 21, 2023.
  1. DefunctNeurons
    DefunctNeurons Formula Junior
    May 15, 2018
    413
    Alpharetta, GA
    Trevor
    The battery tender plug that goes into the lower dash had a wire pull out of it, and I can't figure out which of the two remaining wire holes it needs to go back into. There are two wires for the proprietary plug, a red and a black. The black one is in hole 1 and the red one should be in 2 or 3 (see pics).
    Any ideas on how to fix or which hole red goes in? Or even where I can get a replacement dongle (can't find one now).
  2. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,280
    Mel
  3. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    360
    Texas
    Brian
  4. DefunctNeurons
    May 15, 2018
    413
    Alpharetta, GA
    Trevor
    Thanks, don’t use eBay anymore these days so I forget about it. Hopefully these work. I think I’m still going to fix mine so I have a backup. Much appreciated Bob!
    Trevor
  5. DefunctNeurons
    May 15, 2018
    413
    Alpharetta, GA
    Trevor
    Not sure how to interpret that except as “either one would work”. Sound correct? [emoji846]
  6. DefunctNeurons
    May 15, 2018
    413
    Alpharetta, GA
    Trevor
    Follow up: I purchased the charger adapter as linked above and it finally arrived this week. Didn't work at first but I had an extension cable from CTEK I was previously using. When I removed the extension the new adapter worked just fine. Thanks all!!
