Need help identifying a 355 part | FerrariChat
Discussion in '348/355' started by jesasinowski, Nov 26, 2014.
  1. jesasinowski
    jesasinowski Rookie
    Mar 24, 2011
    7
    #1 jesasinowski, Nov 26, 2014
    Hi All.
    I could use a little help with identifying a loose part I found when pulling the battery from my '99 355 F1 Spider. It was sitting unattached behind where the battery was mounted.
    It has five components (all names are my own and likely incorrect/imprecise):
    (1) The black frame. This hold the other parts and has a couple of holes which look like mounting holes (for a screw or bolt) or alignment holes (for pins).
    (2) The black plunger. This is the piece that pokes out from one side and narrows. There is a spring that pushes the plunger back toward its resting position.
    (3) The light gray latch with 8 raised dots. When the plunger is in its resting position, the latch can't really move much. When the plunger is depressed, the latch can be pressed down to prevent the plunger from returning to its resting position. There is a spring that pushes the latch in the direction that will release the plunger.
    (4) The spring for the plunger
    (5) The spring for the latch
    I've attached a couple of photos of the part in question, as well as one showing the general location where I found it.
    Any clues as to what this might be?
    Thanks!
    - John
  2. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Clearly you have found the elusive springy latching thingamabob. Congratulations! Was the fuse in it good or was it blown, as they usually are?
  3. jesasinowski
    jesasinowski Rookie
    Mar 24, 2011
    7
    Thanks!
    I'm afraid the fuse had blown so completely that there was nary a sign of its former existence.
  4. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    what is it and what does it do?
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Very peculiar. Was it just laying there loose?
  6. jesasinowski
    jesasinowski Rookie
    Mar 24, 2011
    7
    Yes. Either it was always loose or was freed by my battery removal efforts.
  7. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Used to "snug up" a small sized battery?
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,651
    San Carlos, CA
    Mitchell Le
    That is not a thingymabob, it is definitely a thingymajeek.
  9. jesasinowski
    jesasinowski Rookie
    Mar 24, 2011
    7
    #9 jesasinowski, Dec 9, 2014
    Here's an update on the mystery part.
    First, the mechanism in the little part freed up a bit after playing with it. The light grey latch can now be pressed, causing the black plunger to retract.
    I spent some more time trying to identify it, including:
    - Looking through the parts diagrams for other 355 variants and some of the 348's and 360's.
    - Google image searches for terms related to battery clamps, retainers, hold downs, latches.
    - Browsing the web sites of several battery manufacturers and online stores
    - Chatting with a knowledgeable-sounding guy at a local auto parts store
    All turned up nothing particularly useful.
    It does look like the black plunger fits nicely into the notches found on several sides of the bases of some batteries, as shown in the attached photos.
    My guess is that this part was designed to help retain car batteries, and the light grey latch is a push-button release.
    I re-installed the battery this morning. Again I noted that there was no place to attach the mystery part. The battery has the triangular indentations on three sides. When sitting in the car, the long edge facing the car's nose has no triangular indentations, and the one facing the wheel has the indentations but is clamped by the Ferrari battery clamp. However, to install that clamp, the battery has to be moved toward the nose of the car slightly, at which point it doesn't sit as securely.
    So, with the battery being just slightly too big to fit as intended, I suppose that the mystery part somehow helped hold it in place. How? I don't know - there are no attachment points for it.
    Unless I learn anything new, that likely brings this thread to a close.
    If there were a prize for the closest guess, it would go to vracer :)
    Thanks for the help!
    - John
  10. Oengus
    Oengus F1 World Champ
    I thought it was a heavy duty brake pad ;-)
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    After market battery hold down bracket. Or an after market alarm component related to the battery.
  12. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    i suspect a holder for some sort of tracking device. i had a load of them under front carpets in mine. in front of battery would be a good place to place it.
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Did a google search by image. Nada
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Its a glove box latch
