Need help identifying this leak | FerrariChat
Discussion in '348/355' started by FerrariDeeJay, Mar 16, 2013.
  1. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    #1 FerrariDeeJay, Mar 16, 2013
  2. stevew3765
    stevew3765 Formula Junior
    Oct 27, 2012
    716
    Tulsa, Oklahoma USA
    Steve Wool
    Hang in there FDJ, a pro will be along any minute to help...:>)
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Shift shaft. How much? Doesn't look like anything to worry about.
  4. FerrariDeeJay
    Jun 2, 2009
    418
    Chino, CA
    Michael
    It is leaking a lot from the rubber boot. I wiped it down to take the picture.
  5. ClydeM
    ClydeM F1 World Champ
    11,935
    Wayne, NJ
    Clyde E. McMurdy
    If it is the shift shaft, then replacing it is pretty easy. There's a thread on here about it. It's a seal and the boot. I'm guess about an hour of work. I did it about a year ago & have a thread on it too.
  6. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    Yes I have seen more than one 355 with this leak. Pretty easy fix.
  7. Big Lebowski
    Big Lebowski Formula Junior
    Jan 24, 2013
    337
    Peach state
    Brownie
    I just had mine replaced while it was at the dealer for some other things. Seal and dust boot were a couple of hundred bucks, labor was about 2 hours. They also had to replace the cross member underneath; it was bent from (presumably) someone using it as a jack point. Common repair on our cars.
  8. gus355
    Aug 3, 2011
    569
    B.C. and WA
    The boot is $80 and the seal is $3.67
    Two hours might include replacing the crossmember.
