Hi all, I have looked through the wiring diagram, can't quite figure out what they belong to. I found them at the bottom of the tunnel, while I was changing out the main wiring harness that leads to the tunnel switches, They were not connected to anything. One is a double black, and the other is a double yellow This is for my 87GTB Regards Image Unavailable, Please Login Image Unavailable, Please Login
Thanks for your response I forgot to mention this is an 87GTB, I will edit the original post.. I will test the rear window connectors, but it is working at the tunnel level. Regards
