Need help on 348 critical ground point | FerrariChat
Discussion in '348/355' started by jesada, Jul 7, 2007.
  1. jesada
    jesada Rookie
    Dec 8, 2003
    21
    Bangkok, Thailand
    Could you please tell me where is the critical ground point of 348?
    I had a clicking fuel pump's relay problem. After chainge the foot rest fuse box and fuel pump, the problem is still. I think it shold be GROUND problem.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Well one main ground point is for the negative cable coming off if the battery. It gets grounded to the frame, and also is attached to the gear box, from the frame. There is also the issue with the bullet style connectors running to the starter from the battery, and, as I said, from the battery to the frame. If you still have those bullet connectors, I recommend putting in solid cables in place of them.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    A faulty crank sensor or crank sensor wiring problem will cause the ecu on that side of the engine to turn off the fuel pump relay as a safety precaution (e.g. engine stopped by a wreck, fuel pump flowing fuel through broken fuel lines via the wreck).
  4. jesada
    jesada Rookie
    Dec 8, 2003
    21
    Bangkok, Thailand
    Thank you Ernie an No Doubt.
    The crank sensor just changed. I'll recheck the wire to ecu but it out of reach in the fire wall. DO you have any solutions?
  5. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Check to make sure that the wiring loom, going through the fire wall, hasn't been cut into buy the metal in the hole, in fire wall. There is a rubber boot that is supposed to be there. If it isn't, the metal could have worn into the loom and caused a short. It has happened to others in the past. It may not be the cause of your problem, but then it again it may.
  6. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    Ernie , it's time to change that bullet ground connector to my battery, should I connect the new solid cable to the frame or the gear box, thanks Bill
  7. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Just to clarify, do you have a front battery or a rear battery?
    If you have the rear battery, your negative cable should go from the battery post to the frame, and then from the frame (same bolt) to the gearbox - a long cable and a shorter cable.
  8. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    rear battery, thanks for the feed back ,so two cables it is. Thanks Bill
  9. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    What Jeff said.
    And don't forget to replace the positive bullet connector under the airbox with a solid cable while you're at it. Basically, solid cables all the way around. From the battery to the frame, frame to the gearbox, and from the starter to the battery, all solid.
  10. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    Thanks again guys
  11. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    Should I use SS or cooper, braided
  12. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    Started the 348, and I noticed that all the gauges stopped working, ground is definitively solid, no tach,no oil pressure,no horn,nothing, just lights and signals work, what now!
  13. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Did you remember to connect the loom up under the left rear fender well to the positive terminal on the battery? It should have been attached to the connector on the old bullet connector at the battery. So have a look at that and make sure it's connected.
    The next thing you'll want to look at is the round twist on connector, on the left rear shock tower, in the area of the charcoal canister. Check the condition of the connection.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Ernie probably not the issue but as far as the fuel pump what about the roll over protection sensor malfunctioning. I say probably not because seems like there's other problems?
  15. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    The roll over valve is mechanical, and there isn't any roll over sensor.
  16. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    I put everything back to where it was connected, Let me back up a little, I took out the 348 last week,and started it up , and noticed that it wasn't running right, but gauges were working.
    Than I checked the coil packs(switched) no change,with the car running I slightly moved the bullet connector and the car stalled, as I moved the negitive bullet connector the ignition was clicking on and off. I cleaned it up connected it and she started, but no gauges were working.
    This am I changed the bullet connectors to solid lines, she started right ,sounds better, can't test drive (rain). But still no gauges
  17. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Ah okay.
    Have you checked the fuses? If they check out okay then have a look at the connections on the back of the instruments. To remove the instrument pod is simple. Remove the two screws, one on each lower corner of the pod, holding in place and then lift it up. It also helps to have the steering wheel lowered all the way down. And again, check the twist on connector on the left rear shock tower.
  18. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    fuses in the foot well or the trunk, thanks for the help
  19. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    weather cleared too the ferrari for a ride runs perfect real strong,
    only signals and lights are working, no horn, no gauges, no heater,no a/c,no fan,, I checked the connector near the rear shock seems ok and tight,
  20. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Fuses in the passenger side foot well. Most of the systems that aren't working on your car have their fuses there, but I'm not sure how you could have fried so many...
  21. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Strange sequence of events, not sure what to suggest, but you might want to look at the main "buss bar" fuse strip, which is located behind the fuse panel in the footwell. Make sure the nuts that hold the strip are tight, and the connections are clean and dry.
  22. F1Tuning
    F1Tuning Rookie
    Oct 25, 2009
    14
    Thanks Ill check it out.
