Need help on a Water Union R&R | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Sep 5, 2007.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello fellow "F"-Chatters,
    This weekend I'm going to attempt to replace a Water Union (Drivers side, water heater nipple), which is a little corroded on my 1979 308GTB.
    I could use any tips on how to remove this thing from the engine block. The nipple is threaded and screws in ward. I might have to resort to using a tap, but wanted to see if it could be done without it.
    Any advice is appreciated.
    Thanks, Guys,
    Chris
  2. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    #2 Mark 328, Sep 6, 2007
    If it is only a "little corroded" and the engine is in the car, you may want to leave it. You can try just an easy-out, however removing that pipe nipple might be difficult and require you to heat it up with a torch to break the nipple loose. I would try to heat it red if possible with an oxy acetylene outfit then tap a spiral easy-out in to the nipple and try to wrench out out with a socket on the back of the easy-out (a 12 point might fit the square shank well enough to extract the nipple.
    Mark
  3. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    That was a brilliant idea! I see it working!
    The use on an easy-out, I wouldn’t have thought of that!
    On my was to Sears to buy one
    Thanks a lot!
    Chris
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,570
    Hell's waiting room
    I had to remove a badly corroded one from my water pump housing. I simply found the proper tap drill size and a tap. Drill it out and re-tap it. Not sure if it would be any harder or have any negative effects working on the block though.
