Need Help on Math Question | FerrariChat
Discussion in 'Other Off Topic Forum' started by jeff, Jun 15, 2009.
  1. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    What is the volume of cylinder 3 feet by 3 1/2 feet. Answer needs to be in cubic feet. Any help would be appreciated.
  2. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    pi * radius squared * cylinder height. I assume you mean it is diameter 3 feet, not the other way around?
  3. UroTrash
    Jan 20, 2004
    40,524
    Purgatory
    Clifford Gunboat
    which is the height and which is the diameter?
  4. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    I guess that would help. I'll try to find out.
  5. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    God help us, you are not trying to figure out the bore and stroke of an ENGINE, I hope???
  6. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    area of the base*height = (pi)r^2(h)
  7. UroTrash
    Jan 20, 2004
    40,524
    Purgatory
    Clifford Gunboat
    In cubic feet... I want to see that machine!
  8. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #8 toggie, Jun 15, 2009
    Could be a big engine he's building.
    Here's an engine with 6 to 14 pistons in an in-line design, each cylinder 38″ and the stroke is 98″.
    The engine weighs in at 2,300 tons and is capable of delivering 109,000 horsepower.
    It is a turbocharged two-stroke diesel used in large cargo ships.
  9. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    Yep, that's the first engine that sprang to mind. Have more pictures of its construction somewhere, but will be buggered if I know where I put 'em...
  10. UroTrash
    Jan 20, 2004
    40,524
    Purgatory
    Clifford Gunboat
    We have them on here somewhere. It looks like a modular engine used for supertankers.
  11. SonomaRik
    SonomaRik F1 Veteran
    wow, the new F600120, can't wait to see the belt change on that one.
  12. BBL
    BBL Formula Junior
    Nov 1, 2006
    658
    Northern California
    Sean
    Some photos here: http://people.bath.ac.uk/ccsshb/12cyl/
    5,608,312 lb/ft of torque. Damn. I always want to round it off, and just say, "5.6 million lb/ft of torque!", but that would be dismissing the other 8,312 lb/ft as irrelevant.
  13. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Oh bother - have I again hijacked yet another man's thread?
    Anyway - on the original question: If you follow the formula (PI x R squared x Length) and both dimensions are in feet, then the answer will be in cubic feet of course.
  14. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    Either 2.9376 Hogshead (US) or approximately 18422.4 Jiggers, depending on which of the above measurements are the bore.
  15. UroTrash
    Jan 20, 2004
    40,524
    Purgatory
    Clifford Gunboat
    Wait....a.....minute.....is Jeffie trying to get us to do his homework?
    Jeffie, tha'ts just NOT right.
    Go copy offa Susie's homework like we used to.
  16. BBL
    BBL Formula Junior
    Nov 1, 2006
    658
    Northern California
    Sean
    The original request for help was satisfied, by you as well as others, before any hijacking took place. Jeff just needs to plug in the numbers.
    Volume = area x depth.
    Area of a circle = pi*r²
    Don't forget to put "cubic feet", or "cu. ft.", or "ft.³" after the numerical value in your answer (and choose only one of them - not "cu. ft.³").
  17. GuyIncognito
    99,967
    A Ferrari leaves Maranello heading west towards Monaco at 200 kph. A Lamborghini leaves Monaco at the same time heading east towards Sant Agata at 180 kph. how many liters of oil will be consumed?
  18. UroTrash
    Jan 20, 2004
    40,524
    Purgatory
    Clifford Gunboat
    Mobil 1 or Olive oil at lunch?
  19. GuyIncognito
    99,967
    see! it *was* a trick question!
  20. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    #20 agup48, Jun 16, 2009
    Alright, my turn for math help.
    __________________________________________________ __________________________________
    Ramiro invests in a CD (certificate of deposit) that pays 5% compounded quarterly for 7 years.
    What is the effective annual yield of the CD? ___%
    What is the overall return after 7 years? ___%
    How are you supposed to find the annual yield if there is no investment number?
    Another question:
    How many compounding periods are there when it says semi-monthly?
    TIA! :)
  21. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Never mind this one, I found the answer. It's 24, if anyone is wondering :D
  22. GuyIncognito
    99,967
    #22 GuyIncognito, Jun 16, 2009
    yield isn't effected by the amt invested.
    semi-monthly = 24 times a year (bi-weekly = 26 times a year). who knew? :)
  23. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    So how am I supposed to find the annual yield, even if no amount is invested? Is there a specific formula?
  24. GuyIncognito
    99,967
    just pick a number (use $100 or $1000, etc to keep the math easy)
  25. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    #25 agup48, Jun 16, 2009
    Alright, I'll try that out, basically all the effective annual yield questions are screwing me over.
    Figured out what I was doing wrong. I had it correct originally, was just inputting it into the homework system wrong, making me miss it. Thanks Chas!
    Once again, I am stumped. I was doing the first part correct, 2nd part nope. :eek:
    What is the effective annual yield of the CD? ___%=(1+.05/4)^(4)-1=5.01% CORRECT
    What is the overall return after 7 years? ___%=(1+.05/__?_)^(__?__)-1=... would it be (1+.05/4)^(2555)-1?
