Need help removing piece on parcel shelf | FerrariChat
Discussion in '308/328' started by flyngti, Jan 22, 2010.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    #1 flyngti, Jan 22, 2010
    Here's a question for the folks who have recently redone their interiors. The rear shelf is basically two side pieces with a small piece in the middle covering the gap. It's #23 in the diagram. It looks like the piece has a vertical stud holding it down. Problem is, I have no idea what's holding this thing. Is it threaded with a nut? Maybe just friction fit? If there is a nut, I have no idea how to access the underside. I've pulled on it, but it seems to be held by more than just stiction. How do you remove this bugger?
  2. gigaleff
    gigaleff Rookie
    Feb 27, 2008
    47
    Switzerland
    The nut is accessible from the engine bay. I replaced it with a wingnut...
  3. Jdubbya
    Jdubbya The $10 Trillion Man
    43,115
    PNW
    But depending on the car the nut may be under an aluminum heat shield that needs to come off first.
  4. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    just get the biggest crowbar you can find and that'll work just as good
  5. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    Me too..
  6. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    OK... that's just wrong, but it made me laugh.
    I remember that precision engineering mantra when I used to work with my brother on elevators during college.
    Measure it with a yardstick
    Mark it with a chalk
    Cut it with a torch!
    <grin>
    Rick
  7. Helmut
    Helmut Formula Junior
    Dec 11, 2004
    640
    Depending on your car you may also have to remove the rear window
  8. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    Ok, I'll check for access through the engine bay. I believe that there is a heat shield in the way, as JDubbya says. It'd be nice if there was just a little more room forward of the front bank.
    How about this one: "There's nothing brute force and ignorance can't fix."
  9. Jdubbya
    43,115
    PNW
    And getting to the nuts to remove the heat shield is actually more work than removing the rest of it. I thought about putting in a small access panel or something when I put it back together. I wish I would have!
  10. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    I just got done removing this thing, what a pain. I love the idea of the wing nut upon reassembly, thanks!
  11. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    Good idea on the wing nuts, putting my together right now.
    Don't mean to hijack but could someone help with putting back together the pieces. There are two foam pieces that I can't recall where they came from. My car's an '89 328. Where do they go, what's the orientation, and sticky side goes where? the pieces are about 8 inches long by 3 inches wide.
    Jeff
  12. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    #12 CliffBeer, Jan 24, 2010
  13. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I got mine loose enuf to use a hacksaw in the car underneath the piece. Shelf was already trashed to being careful to avoid ruining something was not an issue. Put in a new longer metric stud and used a fender washer and wing nut to fasten it when the time came. Just not enuf room and articulation in the engine compartment to get a hand tool (and hand) working through the foil insulation stuff.
  14. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    #14 Rod, Jan 25, 2010
    If you can move the block/spacer from under the panel you should be able to get access to the large washer that holds the panel in place. I pulled up through the whole by twisting it through the hole.. dead easy to straighten out then put a butterfly nut back on to save future problems..
  15. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    Doing a thread revival here.
    I'm in the process of removing the parcel shelf and I've managed to remove the aluminium heat shield in the engine bay but now I'm stuck trying to remove the center nut holding down the small middle piece. Any tool I put on that nut does not seem to fit. Can anyone confirm which size the bolt is?
    miketuason likes this.
  16. Sigmacars
    Sigmacars Formula 3
    1,218
    I am holding mine down with a magnet for years never moved, that one nut is to much work to remove or install.
  17. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    California SF bay area
    Paul
    Wait a minute. I'm supposed to put "parcels" up there?
  18. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    You can put tiny parcels. :p
    But does anyone know the size of the nut?
  19. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
    I believe that a 8mm x 1.0 thread hex nut.
  20. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    It should be an M6 nut, with the tool being a 10mm wrench. Many have changed it to a winged nut.
    waymar likes this.
  21. yelcab
    Nov 29, 2001
    13,546
    San Carlos, CA
    Mitchell Le
    You know I may have remembered incorrectly. This is my 89 328 and it looks smaller than M6, probably an M5 stud. In that case, the nut on the other side requires an 8mm wrench and you can see that I have replaced it with a winged nut.
    Well it's one of the 8mm or 10mm wrench anyway.
  22. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Pretty sure you're right. I didn't face any challenge there... just put the socket on and removed it like the other two on the outer ends.
  23. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    Thanks for the help. I'll continue trying with the 8 mm.
  24. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    You might need a deeper socket; be sure it's engaging the nut.
  25. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    At the moment I was even struggling with the 8 mm spanner. :\
