Need help to build a clutch tool 355 | FerrariChat
Discussion in 'Technical Q&A' started by fana355france, Dec 6, 2007.
  1. fana355france
    fana355france Formula Junior
    284
    France
    nicolas
    #1 fana355france, Dec 6, 2007
    Hello my friends, I m going to rebuild my 355 clutch and would like to make my tool to remove the nut on photo.
    I know how to do but need the size.I tried to look on the car but I need to remove the exhaust.I would prefer toi make the tool before to remove it like that I can still drive my car for a week more...
    Do you have the sizes please ?
    thanks
    Nico
  2. fana355france
    284
    France
    nicolas
    #2 fana355france, Dec 6, 2007
  3. Testa
    Testa Karting
    Mar 28, 2004
    50
    Why do you not simply buy this tool ? For example from hill-engineering.
  4. Ricambi America
    Sponsor Owner
    RNT-60 at Hill Engineering.
  5. fana355france
    284
    France
    nicolas
    Why to buy something I can make myself ? for 0$ ...I have done the tool to put the disc in the center when i done clutch on my 348, but I did not build this one..
    thanks for help.
  6. fana355france
    284
    France
    nicolas
    I bought them a set of whhel bolts very good quality but this is different from a tool I will use one time.
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  8. walkaway
    walkaway Rookie
    Nov 21, 2007
    40
    walkaway
    a universal 'c' spanner could remove this, would save alot of hassle... if ur still stuck a hammer and punch should remove it handy enough aswell... its not butchering... plenty of people have done it.
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Removing isn't the problem. It's re-installing with proper torque. Hammer and punch can't guarantee you that proper torque is reapplied upon re-installation.
  10. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Just buy a cheap socket and some woodruf keys. Weld the keys onto the outside of the socket and your all set. Should take only a few minutes to make.
  11. walkaway
    walkaway Rookie
    Nov 21, 2007
    40
    walkaway
    very true, buy he only asked how to remove it ;op lol.
    know of the same people that use the hammer/chisel technique to tighten it. proper torque to them obviously doesn't matter. but as far as i can remember this big nut is for adjustment so positioning is more important (if i'm wrong please correct me. i tend to deal with newer cars more). so once its 'sweetly' tight it should be grand.
    p.s... thats a shiney clutch housing you have. its a credit to its owner.
  12. fana355france
    284
    France
    nicolas
    many thanks for this reply
    Making a tool is better to respect the good torque you are true.
    I will make pics of it when done.
    What is the good torque to re-install it ?
    many thanks
    nico
  13. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    Here you go, just do this.... sounds like a smart idea!
  14. vincent355
    vincent355 F1 Veteran
    6,532
    Wine Country
    Vincent
    or a piece of pipe, ground to fit with a square hole in the top for the wrench. Works good...original tool is beaucoup dollares
  15. vincent355
    6,532
    Wine Country
    Vincent
    the mechanic at the dealeship put it back on with a 3/4" impact hammer...tight!!!
  16. Terry
    Terry Formula Junior
    Nov 3, 2003
    250
    Cheshire, UK
    Terry
    I tried a home made tool on mine which was insufficient.
    I also tried to avoid buying a tool for one time use but did end up buying the Hill tool.
    That nut was very tight, someone had applied thread lock.
    That tool is very accurately made and I can not imagine trying to remove that nut without it, worth every penny.
    A little tip, loosen (and tighten) the nut with the housing still fitted to the car - makes it easier.
  17. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
  18. fana355france
    284
    France
    nicolas
    Nice job and a red tool is faster than another !
    Im making mine at the moment too.I finaly removed the clutch today, there is some oil in the mecanism, a little oil leak on the trust bearing, nothing realy bad...I will make : disc + clutch TO bearing seals+bearing+repack flywheel because it is noisy , even if the kluber grease did not went out...I hear many clac clac at the back of the clutch even if it work well..
    Will send pics soon
  19. fana355france
    284
    France
    nicolas
    Do you think I should change the little bearing behind this Nut ?
    my car have 45 000 km
  20. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Cool, looking forward to seeing pics. :):)
    I did not replace my bearing and I had 34,000km when I replaced my clutch. So...........spin it and see if it feels fine. If it spins smooth and does not feel 'grumbly', then I would not worry about it. But your car, your money mate. :)
  21. fana355france
    284
    France
    nicolas
    #21 fana355france, Dec 10, 2007
    Hello here are the first pics.
    I ordered in at local dealer the 3 seals but can not find the bearing ref skf 13 13 1 13 631107B
    I have contacts with Ferrari parts dealers non official and will order soon but I need to know with type is mine because there are 2 types of clutch release biring for 355...dont know if mine is like 348 or not
    As sonn as I get the seals I will tell you costs and refs.
    The new disc thikness is 9mm and the old after 45 000km is 7mm.
    thanks
  22. fana355france
    284
    France
    nicolas
    #22 fana355france, Dec 15, 2007
  23. fatbillybob
    Aug 10, 2002
    29,263
    socal
  24. fana355france
    284
    France
    nicolas
    I just understood right now that to open the flywheel ther is a circlips to remove under the bearing ! I will make a photo of it because never seen it on this forum and did not understood all the words of the text descibing the procedure.
  25. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Cool man. Looks like you are having fun! :):)
