need help to replace drive gears bearing | FerrariChat
Discussion in 'Technical Q&A' started by 82 308gtsi, May 12, 2004.
  1. 82 308gtsi
    82 308gtsi Rookie
    May 12, 2004
    9
    need to replace 2 set of outside/inside drive gears bearing (timing belt pulley) and the oil seal for the main shaft placed right under 2 timing belt pulleys.
    The problem is that I am not able to remove the cover even after I have completely removed all the nuts & studs. I spoke with one of the sale rep. at T.rutlands. he said there are 2 more nuts inside the cover which is used to secure the oil pressure pump and they are only accessible by removing the oil panel and reach them that way.
    Is it really that complicated ? Anyway. I removed all the nuts arround the oil panel. the panel did not dropped out as I expected. Seems like something is in the way. What could it be?
    Anyone out there done this before? Please help!!!!
  2. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    I hate to break it to you, but your problem sounds just like mine. The bearings on the lower belt pullies are shot, right? Even if you get the pan off, you can't get the shafts out the side to press on the new bearings. The answer is removing the engine from the car. Then, you obviously fix all of the other things that are probably wrong with a 20+ year-old car. I was quoted 60 hours plus parts.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,664
    San Carlos, CA
    Mitchell Le
    1. remove dipstick tube
    2. remove oil temperature sender
    3. remove oil pan
    4. remove oil baffle
    5. reach up and remove oil pick up tube (3 bolts 10mm size, very hard)
    6. remove all studs to the bottom of the timing cover
    then, in addition to what you have done, it will come out. This is not an easy job, for anyone. If there are other things you want to do with the engine, then it is better to remove it from the car.
    The complete procedure has been written up by Verell and Rob Garven. Please do a search and you'll find it.
    Good luck.
  4. 82 308gtsi
    82 308gtsi Rookie
    May 12, 2004
    9
    Thanks to all those responded. Oil pan is now removed. I can barely feel 2 bolts with my fingers, One of the bolt is totally out of reach due to limited space, no wiggle room at all.
    Any special trick to get those 3 bolts out?
  5. tbakowsky
    Sep 18, 2002
    20,037
    The Cold North
    Tom
    This is were you have to make up your own tool. Use a shallow 8mm 1/4 drive socket, with a flex elbow. You may have to make the 8mm socket thinner by grinding the side down. THERE ARE 3 nuts holing the pick-up tube in place. You may also have to remove the studs for the pick up tube aswell.
    Much swearing will take place, so if you have kids, be sure to remove them from the area, and a prist would be handy for instant on sight confessions. :)
  6. 82 308gtsi
    82 308gtsi Rookie
    May 12, 2004
    9
    One crucial point,from where the studs/nuts are being removed?
    Since oil pan needed to remove, is it mean that through the opened sump area I will be able to reach those nuts/studs? Hard to believe this is the way. As I mentioned before, I can barely reach them with my fingers, how is that possible to remove the studs?
    Or I should remove all the studs surround the cover and maybe able to lift it high enough so that those nuts/studs become accessible?
    Thanks for all the info given.
  7. yelcab
    Nov 29, 2001
    13,664
    San Carlos, CA
    Mitchell Le
  8. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
