Need help with 550...again | FerrariChat
Discussion in '456/550/575' started by italiafan, May 31, 2010.
  1. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    Hi guys,
    Me again!
    Happy Memorial Day.
    Remember how my gas filler cap wasn't working? Well it stopped working again. I was at a light yesterday and a person in the car next to me pointed out that I have no brake lights. I checked the manual and the gas filler cap, brake lights, and wipers are on the same circuit.
    The wipers work, and the fuse is OK. (BTW: the turn signals and reverse lights work fine.)
    Any thoughts?
    Thanks, as always.
    Rob
    Oh....and the CEL is on again...but I have come to just ignoring that it is so frequent. :(
  2. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #2 toggie, May 31, 2010
    The brake lights not working may or may not be a related problem. My advice is to resist the temptation to assume they must be interrelated.
    As far as the gas cap being stuck, when the key is in the on position and you work the toggle switch on the dash, do you hear a clunking sound (back by the gas cap) or not?
    If yes, then your release mechanism is working but it is somehow jammed. Probably the rubber flap again. To fix, have some one sit in the car and work the toggle switch every few seconds or so and, from the outside of the car, gently poke and pry on the edges of the gas cap using a semi-soft thin tool. Often this will result in the gas cap popping open. If it does, look at the position of the rubber flap at that moment to try to figure out what made it jam the last time the cap was closed.
    If no clunking sound when the toggle switch is worked, then you probably have some sort of electrical problem. Trouble shoot the fuse first.
    Good luck.
  3. italiafan
    16,121
    Thanks.
    Fuse is OK.
    There is no sound when working the gas filler toggle switch. Both gas filler and brake lights on same circuit, though so is wiper and that is working.
    I wonder if there is a sub-relay that does just the gas filler and brake lights.
    I doubt it is much money to fix, just annoying becasue I can't drive the car without brake lights (even though it is an Italian supercar and I never brake! :)).
  4. italiafan
    16,121
    can anyone help a brudda out?
  5. tazandjan
    39,195
    Rob- I would tend to suspect the brake light switch on your brakes. You should be able to adjust the height on the switch, IIRC. Away from my manuals, but check the switch and see.
    There have been multiple threads in several forums on fixes for the gas door, including rough plastic bits, rubber flap interference, etc. A short taking out two of several systems on the same circuit seems like long odds to me. Back later today.
    Taz
    Terry Phillips
  6. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Corroded ground wire?
  7. Rifledriver
    37,121
    The factory wiring diagrams for the 550 are the worst and most inaccurate Ferrari ever produced. Fixing electrical problems just needs to be done the old fashioned way. Find a Ferrari mechanic good with electrical. That is the rarest kind BTW. Few mechanics are really all that good at electrical.
  8. italiafan
    16,121
    Thanks guys, please see my other thread.
  9. fatbillybob
    Aug 10, 2002
    29,064
    socal
    If you really don't want to spend time finding the brake light issue just wire up new ones. Brake lights are stupid simple. Make sure the switch at the pedal works then just wire it up.
  10. italiafan
    16,121
    Thanks FBB. Can you direct me to where the brake adjustment switch is?
    Many thanks guys, as always.
  11. 308 GTB
    308 GTB F1 World Champ
    11,729
    New Jersey
    Barry Wolinsky
    #11 308 GTB, Jun 2, 2010
  12. BillN
    BillN Karting
    144
    Farmington Hills, MI
    Bill Nichols
    I had a similar problem with my gas cap, and after reading the threads and making sure I was in the right condition to test it, I discovered the switch itself was intermittent. I replaced the switch and it worked fine. before ordering the new switch I pulled the existing switch out and checked it for continuity and found it was inconsistent.
    Worth a try.
  13. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    You really believe is true?
  14. 308 GTB
    11,729
    New Jersey
    Barry Wolinsky
    These might just turn out to be some really easy fixes, DIR. The fact that his wipers are working means that perhaps this is just a matter of a faulty stop light and gas lid switch. A fellow 550 owner I know had an intermittent CEL which turned out to be a loose harness connection.
    So take heart, Rob. You might not look like this...:eek:...when all is said and done.
    Barry
  15. italiafan
    16,121
    Alas....the 550 is gone, as is the Maserati GranSport.
    I picked up my new Porsche Panamera Turbo today...Basalt Black on Black with Carbon Fiber package, Ceramic Brakes, and a few other goodies.
    The car is deceptively fast.
    The light turns green, stomp on it, no drama, smooth, shoved back in seat, after about 3.8-4sec look down and going 60 and all the other cars have faded into the distance.....I'm gonna have to be careful about my license!
    550 was a gem, and I lost a lot of money over the last 18 months...perhaps the hemorraghing of money was about to stop, perhaps it would have picked up into a full on exsanguination. The Maserati never gave me trouble, but off warranty and 30K miles I could smell smoke on the horizon.
    Thanks all.
    I'll continue to restore my 1959 Maserati 3500GT...and who knows.....may have a Ferrari again some day.
  16. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    That was fast! Did you trade-in the 550?
  17. italiafan
    16,121
    yep..took a beating
  18. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    You could have let one of us give you that beating you yearned for...
  19. 308 GTB
    11,729
    New Jersey
    Barry Wolinsky
    #19 308 GTB, Jun 3, 2010
  20. henryr
    henryr Two Time F1 World Champ
    22,422
    Atlanta
    Juan Sánchez Villa-L
    jumped from two beatings to another whooper. what's msrp on those things, $135k ish ?
  21. Etcetera
    Etcetera Two Time F1 World Champ
    24,015
    C6H14O5
    Ouch.
    :eek:
  22. italiafan
    16,121
    $155K....... :eek:
  23. henryr
    22,422
    Atlanta
    post some pics of this bad boy.....
  24. 00 550
    00 550 Formula Junior
    Oct 20, 2009
    412
    FL
    That guy
    Got followed home by a gentleman who informed me my brake lights were not working. Unscrewed switch, which should make the lights stay on from what I understand. Then pulled offswitch and opened it up. Looked to have some black corrosion on the inside. I sanded it off and replaced---no brake lights. Then I took a piece of speaker wire and put both ends in to the female ends of the connecting wire which I believe would complete the circuit (as Rifledriver recommended) and cause the lights to iluminate--no luck. BTW, I already checked the fuse, and the wipers work which are on the same fuse. Anything I missed or something I did wrong to diagnose? I did just replace a dead battery, and recently received a jump start when the old battery was dead. Thanks for any help
  25. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Are you doing this testing with the ignition on?
    Can you test with a test light or meter whither or not you have power at the switch?
