Need Help With a Door | FerrariChat
Discussion in '308/328' started by surfdwn, Jan 8, 2022.
  1. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    I bought this '87 328 early last Fall and have been going through it. So far I have replaced the timing belts and tensioners, the water pump, coolant hoses, some evaporation cannister hoses, brakes, and the A/C receiver/drier. The A/C still needs work, but at least it is charged up now.
    I bought the car remotely and had it delivered. I sent to get into the passenger side today to open the fuse panel, and found out the door is jammed. It appears to be locked, and won't open. The manual lock will not push down and the inside release does nothing.
    Any suggestions? Can the inner door panel be removed with the door shut? Today was actually the first day I have tried that door.
    I am not at all disappointed with the car, as it looks terrific and runs great. I am learning as I go....
  2. BigTex
    79,380
    Houston, Texas
    Bubba
    No, it won't come off, that said the speaker grill (early cars) Gets you in there and you need to soak down from the window slot toards the lock rod/latch terminations.
    It's hard to desribe but the door key makes it all "spring up" and "spring down" somehow mechanically.
    Good luck and also lifting the entire door up and off the downward stress of it's own weight, may help.
    In the end, of nothing works nothing really rare or specail about the dorr panel, get out a sawzall and find a scrap one later.
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    The door key should push the lock rod, now if it no longer reaches the latch that's the issue.
  4. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    The key will not push the door lock down and binds when you try to unlock it. I think I will need to get the door panel off, but don't know if it can be done with the door closed.
  5. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    I would hate to mess up the door panel, as it is perfect.
  6. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    Would a "slim jim" approach work on these cars?
  7. BigTex
    79,380
    Houston, Texas
    Bubba
    Yes, there's not much lock rod protection.
    Yes on a 328 I would share your reservations, about cutting a nice trim....call the teenager at Pop a Lock and have him give it a go.
    You have electric locks I guess..
    "Well, that's a horse of a different color!"
    The Wizrd
    Saabguy likes this.
  8. Cennzo
    Cennzo Karting
    Jan 29, 2020
    111
    Sausalito CA
    Vince Dattoli
    Do you have AAA? If so, it might be worth a call. I’m sure this wouldn’t be the first time they “broke” into a car when a person locked themselves out . . .
  9. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    You could take off the door panel on the other door and have a look at the mechanism to figure out how to get the internal bits in the other door with a wire or slim jim.
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,218
    Gold Coast, Aust.
    Patrick
    Mate, pushing the knob down locks the door. Try pulling it up.
  11. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    The locking "knob" is up and won't push down. I thought of the suggestion last night to take the other door panel off and see if I can determine how the system works and see if I can see how to release it. That's what I will do.
  12. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    I got it o[en this morning. I used the key to cycle the locks from the driver's side a couple of times, and the door could be opened. Thanks for all of the suggestions!
  13. wfu97
    wfu97 Karting
    Jul 15, 2018
    101
    North Carolina USA
    Scott
    Glad you got it opened. So you just locked and unlocked several times with the key on the driver's door and it eventually worked? Just asking for clarification in case I ever run into a similar problem. Thanks!
  14. BigTex
    79,380
    Houston, Texas
    Bubba
    My suggestion to lube it all still stands, sounds like the locking solenoid is sticking or failing, really
    GREAT news, though and welcome to the family!!
    Kent Dellenbusch likes this.
  15. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    Yes, using the key to lack and unlock the driver's side door several times unfroze the passenger side. It opens and closes like a dream now. I took the car our for a "shake down" run today after all of the maintenance (belts, etc., etc.) that I did. What a great machine this thing is!
    wfu97 likes this.
  16. BigTex
    79,380
    Houston, Texas
    Bubba
    *smiling*.........
  17. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    People often used white lithium grease on lock mechanisms, which is bad idea, as it hardens with age.
    What you may need is just take the door panel off, and get the lock works out and clean up and relube with something that won't harden . Do NOT use WD-40.
    Doug
  18. surfdwn
    surfdwn Karting
    Sep 28, 2005
    140
    Freeport, Fl
    I did use white lithium grease. I have to take the door panels off anyways sometime to fix the stereo speakers and speed up the windows, and figured I would tackle it then.
