Anytime my friend What it is saying is that Roxio writes a "to be continued" on the first disk you burn of a multi-disk set. If your burning 900MB of data and it won't all fit on one disk, then it needs to burn 2 disks. I "assume" your trying to continue a project and Roxio is asking for the first disk in the set. I could be wrong, but I believe thats what is going on.
I always just add files / flders until the CD is about 80-90% full then burn it. You can save the file list to burn another copy in the future. You might have to do this 3 times or so for the 1.5GB you are trying to save. I used to have some trouble because I had the write speed set up too fast, but you should not be having that with a higher rated disk. It could be that you are trying to mix burn speeds on a single batch of files to write and the program only sets up to stream the data at a single speed or something... BT
I don't have a project larger than the disc, I just add folders until I can't add more, then go to burn, it then kicks the CD back out.
That's strange. In the thread I linked to the OP said it was a registry issue, but never posted why or if he fixed it.
