Need help with CEL P0153, P0159 and P1448 | FerrariChat
Discussion in '348/355' started by flat_plane_eddie, Jul 3, 2016.
  1. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor Silver Subscribed
    Mar 30, 2013
    3,165
    NE FL
    Eddie
    OK so about 300 miles ago I had the following codes (I put question marks so I can be corrected in case what I wrote is wrong):
    Pending Trouble Codes:
    P1448 (Bypass thermocouple?)
    P1449 (Left cat thermocouple?)
    P0159 (Bank 2 sensor 2, which if I understood correctly, is the downstream O2 sensor on the left side?)
    Trouble Codes:
    P0153 (Bank 2 sensor 1, upstream O2 sensor on the left side?)
    P0159
    It's also worth mentioning that when I dropped the car off at the mechanic for an oil change, the SDL came on briefly when cold. This is the 2nd time it happens in about 3 months although when it happened last the car was hot.
    I then swapped the cat ECUs from left to right and also swapped the thermocouples between the bypass and the right cat. Proceeded to clear codes and after 250-300 miles I have these codes:
    Trouble Codes:
    P0153
    P0159
    Pending Codes:
    P1448 (I cleared the codes again shortly after and this one has not come up again)
    I obviously swapped the cat ECUs and thermocouples around to see if the problem would follow them but it's not. What is also baffling is that I have new downstream O2 sensors with mini cat extenders. I also have hyper flow cats.
    So what do I do next?
    hemyhra likes this.
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Slow response codes are often attributed to rear O2 sensor readings. If they are known good, then consider removing the extenders.
  3. flat_plane_eddie
    Mar 30, 2013
    3,165
    NE FL
    Eddie
    Interesting, don't think I've seen that mentioned yet. Is the Moronic that off that one O2 sensor would work with the extender and one wouldn't?
  4. plugzit
    plugzit F1 Veteran
    7,760
    Redondo Beach, CA
    Bruce Bogart
    Does it give these codes with stock cats?
  5. flat_plane_eddie
    Mar 30, 2013
    3,165
    NE FL
    Eddie
    I never had stock cats on it, bought the car with straight pipes but those were swapped out right away.
