Need help with charging system light? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by the Wizard, Feb 6, 2008.
  1. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Oh you guys are a HOOT! Glad to be providing so much entertainment...haha. Didn't realize the newbies were only allowed in to provide the comedy.....
    As sh*tty as I'm feelin' I was pretty happy with getting as far as I did yesterday. If I wasn't working on that car I was in bed. Hopefully today I will go down and try to get that sheild of the back of the alternator to make the electrical tests. But I'm not even sure I can get my hands in there....may need to rent a midget...haha.
    Sure wish you guys lived on the "correct" coast!
  2. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Midday update.....Rv5 (Ross V) took over one the progress. He got the shield off....said my hands never would've fit. We unplugged the negative lead from the battery to the car? Is that connector of the negative circuit stock? Took the wire off the D+ post. It had a spade connector right there at the alternator, but we removed the nut anyway. Is that connector stock? Then plugged the battery back in, turned the key on, and shorted that wire to ground. That dash light came on as never before! haha
    So I guess we're on to the electrical test. To review....we should re-connect the D+ wire? or leave it off? Then measure voltage on that same post as a function of rpm....or at least over 1000rpm.
    As soon as the Lakers game is over of course.....
  3. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Lakers won....cool!
    Ok, tested it both ways. Without the 12 volts connected to the D+ post I can see a volt or a volt and a half at low revving...seems to vary slightly with rpm. Now that we know that wire is continuous this is the same measuremt I made from inside the car on the alternator side of the bulb socket (with the bulb out). Then we connected the wire again. With the key on I got 12 volts at the D+ post.....and with the engine running with low revving it stayed constant at just slightly less than 11 volts....no real change with rpm.
    Time to pull it?
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Wer're sorry for your loss ,and I guess you need to pull it. HAHA have fun , we are here to help. See ya
  5. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    I just noticed that mount for the alternator is removable....thank god....so I guess it can squeeze out. We'll start looking for a rebuild house. But what about that water line? The coolant is probably good, based on recent services, but we could change it anyway. Should we just pull that water tube out and forge ahead? Or do we need to know more now before taking that step?
  6. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Hey guys.....the alternator is totally disconnected....just waiting to hear how we should handle that water line.....then out it comes!
  7. BillyD
    BillyD Formula 3
    1,840
    Pacific Northwest
    Bill
    No use putting used $8.00 coolant back in, I'd loosen a lower clamp, slide a screwdriver between the hose & pipe and let it flow and then replace with new, just don't let the pets or wild critters lick up the anti-freeze as its deadly. Be sure you're on a coolant line & not a fuel crossover line, ask me how I know!!!!
    Bill
  8. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Alternator is out!
  9. Steve King
    Feb 15, 2001
    4,367
    NY
    OK great you can now get your Fcar certificate of service. HA good going now please let us know how you make out. Also depending on where you get the rebuild make sure that they give you the pulley back with the alt. I would also get the 85A upgrade. Any auto electric place that rebuilds Bosch alts can do the job. Have it bench tested before the rebuild to just make sure it is bad. Enjoy
  10. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Hey Guys,
    Took it in to a place that was recommended to us today. The guy knew all about the 85A upgrade and the pulley issue. We'll let you know the results of the bench test tomorrow.
  11. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    The alternator house reports "No Charge" as the result of the bench test. Should have it back in a day or so.....$165 with the upgrade.
  12. Steve King
    Feb 15, 2001
    4,367
    NY
    OK Ross , great to hear. Now while you have the antifreeze drained here is a little trick for future draining of the system. Look under the front of the car just behind the steering rack and in the center. You will see a rectangular access cover with about 10 bolts. Remove this cover and you will see some water hoses. Go get yourself a plastic tee from your auto parts store. The type near the antifreeze shelf that has an assortment of fittings. It has 2 push on ends and the tee has a screw type water hose end. Splice this into the 3/4" hose and turn it at a 45* angle so you can bolt up the cover. You are done. So next year when you change the antifreeze you just slide your 5 gal. oil drain bucket under the fitting and remove the cap and drain it. Real simple and quick. Buy the way how much are they getting for the alt. rebuild these days. I had mine done 8 years ago for $90 (85A upgrade too). Good luck.
  13. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I love when a plan comes together...Excellent!
    Before she's buttoned up, now might be a good time to replace that alternator belt. As you may know, she's not a garden store variety automotive belt, but rather an "industrial type" belt, specially a Gates Polyflex belt. These are avaialble through Gates Industrial distributors, or your local Ferrari parts peddlers...
    Regards,
    David
  14. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Hey Steve,
    I'll look for one of those fittings today....sounds like the standard backflush fitting. The rebuild with upgrade is $165. This car uses a standard antifreeze I assume (my NSX doesn't)?
    Hey David,
    Ahhh yes....The A-Team...one of my favs! Ever notice how even though every show used lots and lots of automatic weapons in every direction, that no one ever got shot? HaHa The car supposedly had recent service, uncluding all the belts, and even though we're having some trouble getting the actual paperwork from the independent in Fresno that alternator belt does look brand spankin new....I can see Gates written on the very shiny surface. Would it be as easy for me to see the cam belts to verify? Those are the ones we're really worried about.
    Ross
  15. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Alternator going back in...dash light now works....will finish tomorrow......
  16. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Ok guys....the alternator is back in. The dash light came on with the key of course and stayed on when it started...but when we reved it and that puppy went out....cool! Measured 14.6 volts at the battery!
    You guys are amazing!!!
    Thanks again...have a hunch we're gonna need you a lot more...haha....Ross
    p.s. maybe I'll get my first drive soon.....
  17. Steve King
    Feb 15, 2001
    4,367
    NY
    Nice going and congratulations
