News
Need help with codes.
Discussion in 'Technical Q&A' started by agioiella, May 14, 2009.
  1. agioiella
    agioiella Rookie
    Aug 29, 2005
    16
    East Longmeadow, MA
    Alfonso Gioiella
    #1 agioiella, May 14, 2009
    Hello does anyone know what these codes mean P1115 and P1119. All it says is it is manufacter specific. The vehicle is a 97 355 spider. Any help please. Thank you
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    11,179
    South East
    Jimmie
    They're bound to have come up before - try putting each into search
  4. Ricambi America
    Sponsor Owner
    P1115 O2 sensor, pre cat, bank 1
    P1119 O2 sensor, pre cat, bank 2
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Project Master Owner
    May 10, 2006
    16,218
    Atlanta
    It's man
    when was the last time the spark plugs or ignition system was checked? could be a misfire?
  6. agioiella
    agioiella Rookie
    Aug 29, 2005
    16
    East Longmeadow, MA
    Alfonso Gioiella
    No sign of a misfire runs great if cleared they come back in 50 miles. Thanks for all the help.
  8. Clown Tech 1
    Clown Tech 1 Rookie
    Apr 22, 2009
    2
    Dealership Near You
    Hello friend,
    These codes indicate a failure of the upstream O2 sensors heater circuits on banks 1 and 2. Being as the code is affecting both banks have you checked the fuse or relay for the O2 sesors heater circuit.
    Just a hunch.
    Good luck,
    Clown Tech
  9. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,269
    Hugh G. Rection
    As Clown Tech mentioned, if you can confirm it is the O2 sensors....this is the correct Bosch part number for a pre-cat O2 sensor for the 1997 355 with 5.2 Motronic. part #13819 (do NOT trust the Bosch look up guides for the 355, they are WRONG)
  10. Skidkid
    Skidkid F1 Veteran
    Aug 25, 2005
    6,667
    Campbell, CA
    John Zornes
    WOW, two posts and you are adding real value to this forum. Welcome aboard! Always good to have more knowledgeable resources here.
  11. agioiella
    agioiella Rookie
    Aug 29, 2005
    16
    East Longmeadow, MA
    Alfonso Gioiella
    I also have a 99 355 kicking a P0153 and the owner replaced all the O2 and that one is still coming back.
